Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
Yep - same problem
Yep - almost same problem. Lacie 500 Gb external drive, properly formatted on same computer that it's attached to. It saves fine, files drag across okay, but cannot be deleted. It keeps saying "cannot delete (filename). Cannot find specified path." Which is b.s., because "the path" is exactly where the file comes from (i.e. G:\(filename)). And even though I can drag files into other folders (as copies) it won't let me drag them into the recycle bin.
Any suggestions?
    Top Expert:
  • LaCie Master
  • 45,552 Answers
Don't drag to the trash can , simply delete them
Posted on Jun 04, 2017
SOURCE: external hard drive
500Gb Lacie D2 Quadra with the same problem of flashing led and not mounting on the desktop (Mac G4 Mirror), traced to the power supply (57w) going down on power, both 12v and 5v supplies are available but the main power to run the drive drops to below an adequate output, hence the clicking and whirring evident from the drive with simultaneous flashing led.
Testing with another Lacie power supply (250Gb D2) this time a 34w unit got the drive up and running, however, and this is the reason for this post, this lower power PSU failed a week later whilst waiting for a warranty replacement from Lacie (5 weeks and still waiting for the new PSU from them. they have no stock)
Message for all Lacie D2 users, check the power supplies first, test with another Lacie PSU, do not run the drive on a lower rating (34w) PSU it will fry it and leave you with another failed power supply.
If you are in a tight spot use the temporary power supply to move your data to another drive and get the correct 57w power supply before running the drive again.
Don't do as I did assume any Lacie power supply will run any Lacie hard drive, they won't, fortunately I had a second back up, but am 2 drives down and no new PSU's available to buy anywhere.
Try and purchase another spare 57w power supply, something all D2 users should do for long term security, as these do not seem to be very reliable and getting warranty support from Lacie on these is currently impossible.
The lack of 57w power supplies from Lacie and its distributors across the world is surely a warning to be noted!!!!!!
Buyers beware!
Posted on Sep 08, 2008
SOURCE: How to i reformat a lacie 500gig external hdd
The Mac OS can't natively write to NTFS (it can write to FAT32 however). But if you install MacFuse followed by NTFS 3-G on OS X then you'll be able to write to your NTFS drive.
Posted on Oct 04, 2008
iklln6
  • 35 Answers
SOURCE: Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Posted on Jul 15, 2009
Geekman
  • 32281 Answers
SOURCE: Lacie extern. hard drive is recognized, but I can't access files
Try connecting the Lacie to another computer, if it doesn't work then the hard disk may need to be formatted using Disk Manager. I suggest you format as a primary partition in FAT32.
If it doesn't work then it is possible that the hard drive in the Lacie has failed.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Posted on Sep 13, 2009
neutronrace
  • 66 Answers
SOURCE: Lacie ext hard drive, 500 GB, doesn't show files but 123GB used
you can always recover your files with the program undelete . exe
verry good working tool.
if you are interested
Posted on Feb 13, 2010
LaCie Big Disk 500GB not showing up
1. the usb connector in the PC may have a broken board contact needs soldering or replacement.
2. there may be a broken USB cord to the external usb drive
3. the electronic controller in the USB case may not be working.
4. A new case may be needed with a new controller.
Jul 08, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Hi I have a Lacie External Harddrive 500gb, when I connect my hard drive to my computer it does not open, instead it gives me a message saying that " disk is not formatted"?
The disk was probably dropped or jolted. You can consider the drive bad now. The arm is broken inside. You can format the drive but most likely it won't work after that. Getting the data retrieved can cost up to $2500-$5000.
Nov 30, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
I have a Lacie external HD 500G which we installed approx. one year ago. It was working great . However recently the mother board in our computer failed and was replaced with a new m-board. Essentially we...
Kevin, Yes you will loose al data if you format it.DO NOT FORMAT as you have your data on it. What I suggest is to get the motherboard of same old model that you replaced. Sometimes the motherboards do not play up with all the hardware. Get the same model motherboard that you replaced. Once that works, copy all data to some other HDD. Or better still send the data in bits by email to yourself. The data would be safe on the email server. And can be retrieved later when all is well. OR attach the drive to some other computer where it works and send emails to yourself. Long and tedious job, but will save your data. And when the drive has started working with your new computer after formatting or otherwise, you can retrieve all the data. and delete the emails from the server.
Nov 16, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
I accidently formatted the drive, now have no
try recovery softwares, download pc inspector file recovery software its free on net
Sep 21, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
I'm running Windows XP professional. Have plugged in my Lacie d2 Quadra (500 GB). Device manager shows that it is working properly, but it is not initialized and it doesn't show up on my windows...
1.
log onto d computer as administrator
2.
start->my computer->manag
3.under storage->disk management
4.ef intialize ndcovert disk wizard appers click next ef not skip to step 8
5.on d selct to disk intialize page click next
6.on d select to disk covert page click next
7.on completing dhese two click finish
8.right click u r external drive nd click format
9.in d format dialog box type d name for u r external hard drive nd then click ok
10.click ok again
Sep 14, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
I have a LaCie 500 GB Exernal Hard Drive, everytime I plug it into my laptop it works fine for a few minutes (various lengths from 2 minutes to 20 minutes) then it causes my laptop to freeze. I no longer...
Are you sure it is not a power problem? If the drive has an external power supply then then will not be the case, but if not, the USB port might not provide enough power.
Also check out: http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Apr 04, 2009 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
LACIE 500 GB HARD DRIVE
i use my external hard disk many times but now when i connect my lacie external H.D to PC it dose not recognized
Jan 30, 2009 | LaCie (300951U) 500 GB Hard Drive
Troubleshoot lacie hard drive 500 gb
all you have to do is put it in a different computer and format it.
Jan 05, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
55 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
