Red oil is transmission input shaft or torque converter seals
Transmission removal for the fix
rear main seal is black or engine oil color and is again transmission removal for fix
procedures are stated in the workshop manual for either or find an accredited service specialist shop with experience on your make of vehicle
looking at up to 8 hours labor time plus parts
SOURCE: Rear Main Seal Leak
To replace the seal, the mechanic will have to either lift the engine or lower the transmission. You will get much better pricing going to a transmission shop (e.g. AAMCO) and getting a quote from them to replace the seal.
SOURCE: Rear Main Seal Leaking
Hello, it's not "easy" but, it's doable.
You'll need to follow the instructions and don't take shortcuts. ask for help if you need it.
Use this link to get an idea of what is involved. Ignore the "remove transmission" part. It can be done without removing the tranny. If you decide to do this buy a service manual to help you. If you have any questions feel free to ask.
Here is the link:
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152801caf2a
SOURCE: rear main seal leaks..does this affect transmission??
A leaking rear main seal will not cause your transmission to leak.
The transmission has its own seal and should not leak because of the engine rear main seal.
Due to the labor involved in replacing the rear main seal on the engine, it is best if you replace the front transmission seal at the same time if possible.
Installation varies on different vehicles but the principles are the same.
SOURCE: rear main seal is leaking on a Ford Mustang 2003 V-6
In order to replace the rear main seal u have to pull the transmission out to access it, u will need a special seal installer tool to install the new rear main "full circle seal", it u don't use the special ford tool the seal will leak again, also if there is a groove worn ion the crankshaft the crank must be repaired or replaced or the or the seal will leak again, so this is avery diff job, a 9 on the scale of 1-10 with 10 being the mos difficult.
SOURCE: How hard is it to replace the rear main seal in a '87 Samurai?
Is it a 4x4 if it is you would have to seperate the tranny from transfer case and drive shaft tp change out seal.If not just drop the drive shaft and replace seal.We are talking about the rear seal at the end of the tranny.
Dear Sir,
Here is the oil leaking Problem Identifying Technique
Engine oil leaks from the valve cover gasket are common.
