SOURCE: orion tv1929
Try doing a code search function on the remote. Perhaps there are similar codes that will work for your TV. Each code could do different yet similar things. It may take a while but it's worth it.
SOURCE: DWT1905 - No CATV/ANTENNA CHOICE
You will probably find your answer in the manual; the unit is built by Funai:
http://www.funai-corp.com/6pdf/om/DWT1905.pdf
SOURCE: unable to access menu with remote control
you cannot enter into menu on most universal remote only on off switch,channel change and volume up and down thats the most you can get out of a universal remote.you will need the originald remote.
SOURCE: orion tv/vcr combo 1921 model with a phillips
These sets don't like universal remotes. It's almost like Orion made them this way. Try this tip http://www.fixya.com/support/r387655-orion_tv_remote_code_here .
SOURCE: Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
