Back to:
Tags:
E-Machines Athlon XP 2200+
Pc power "button" assembly?
posted by brandiamour on Nov 19, 2007
my pc's power button came apart when i took the front panel off. there are two wires (one white and one black), two very small copper strips that are bent at a 90 degree angle, two chips, and of course the button housing. i need to know how i'm suppossed to put this damn thing back together? someone please help!!!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Dec 01, 2007
Thanks for Trying (70)
tonysmith
Rank:Wiz Wiz
Rating: 81%, 119 votes
Wire are came out from u r power supply unit or from case if from case then its belongs to power switch or if back then its belong to power supply units to the switch wire goes to maint board of power supply wire. ok
Thank you
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on pc power "button" assembly?:
I don't want to Accept this solution
Can you Help with these Processors problems?
Processors
My gatewaywas crashing ever once and awhile. The LCD...
Processors
Hi mansoor here, i want to know completely about pentium 5...
Processors
this unit was bought from a casino and the cabinet is...
Processors
hi i keep having a dialogue box appear on my laptop when i...
E-Machines Athlon XP 2200+ (rb-t2200-c67)
i need wiring diagram for power led, hdd led, and power...
Loading problems.
Repair Service
Find Processor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
