Putting bobbin casing back together and want to be sure it is correctly inserted
You can download a workbook here:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&ved=0ahUKEwiY5JCk7-7PAhWIv1QKHbIuDWoQFggzMAQ&url=http%3A%2F%2Fwww.itsastitchonline.com%2Fmastery_on_the_web%2Fmastery_153qe_163_1-4-02.pdf&usg=AFQjCNHHww3jbxbLXZYNj6vuCZE4-kVa8g&cad=rja
How to Clean and Oil Your Bernina Sewing Machine
You may need to wiggle the hook around a little bit to make sure it fits properly. If the race holder snaps easily into place and the bobbin case snaps in and latches, it should be set to go.
Bernina 160 165 170 180 200 730 important steps see that
It is generally not recommended to use canned air on a sewing machine as it tends to force lint and threads further into the machine. Use a soft brush and perhaps some small vacuum attachments to remove anything you are unable to reach.
