Question about Garden
I need a front exhaust for my lovely 021 chain saw where do i go to get it ????
  • kieran_norri Jul 19, 2009
    its a stihl 021 dunna much more about it becuase i was givin it
    many thanx hope u can help
    kieran
  • Joel Friedenberg May 11, 2010
    I may be able to help,but I could use more info. What brand, model # is the saw. 021 is not ring a bell.
    Problem Solver:
  • 13 Answers
Stihl chain saw 021 runs grate till I put bar chain on
Make sure the chain brake is not dragging?
Jan 19, 2017 | Cars & Trucks
How much to tighten spark plug on stihl chain saw model 028?
General rule is to tighten it by hand, then turn it with a ratchet another 1/8 to 1/4 turn.
May 06, 2014 | Stihl Chain Saws, 017, 019, 021, 023 & 025
What causes 021 stihl saw to cut off?
Your chainsaw is running-lean, take off top cover. You should see the air filter. Under The plastic air filter housing is too nuts, 12mm socket is Wot you need next, you need to check these too nuts are tite, these nuts hold the carby to the Intake, all air that goes into the saw is mixed by the carby with fuel. Your saw is running lean. So if those bolts are tite you'll need to check the gasket between the carby and the block....... There are others possibilities but these too are your most likely.
May 03, 2014 | Stihl Chain Saws, 017, 019, 021, 023 & 025
File size sharpening stihl 023C
There are six different chains with different pitches that can be used on this saw. 1/4, 3/8 PMN, and 3/8 P use a 5/32" file; 0.325 uses a 3/16" file; 3/8 uses a 13/64" file; and 0.404 chain uses a 7/32 file. The pitch is ususally stamped on the side of the chain teeth.
Sep 25, 2013 | Stihl Chain Saws, 017, 019, 021, 023 & 025
I HAVE AN O17 STIHL CHAIN SAW AND IT LEAKS CHAIN OIL EVEN WHEN IT IS NOT BEING USED
That can happen. When you go to store it, open the oil cap and then close it to lose the pressure the pump builds up inside.
Oct 01, 2011 | Stihl Chain Saws, 017, 019, 021, 023 & 025
Stil 021 chain saw. It starts easy, but when throttling up, the cain bar will not move. I have disasmbled the covers and am able to move the sprocket with a pair of pliers. How do you remove the...
This sounds like you may have the chain brake stuck on. The hand guard is also a chain brake. release the chain brake by pulling backwards on the handle. If this does not fix the issue remove the clutch by pulling the c-clip and retaining washer. I would look at the bar and chain and make sure they are not bent or damaged. ask a local dealer like www.arcolawn.com for parts or tools you may need. Good luck barterjoe_12.png
Nov 01, 2010 | RTO Spur Sprocket For Stihl 017, 021...
OILER NOT WORKING
Poulan Pro 260 LE chain saw chain bar lube system is not working.
Mar 17, 2009 | Garden
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
