Question about IBM Thinkpad 560 Series Laptop 20h4241 Keyboard
When I hit the 'l' key, the number 3 appears.
This also happens for several other alpha keys - different numbers!
  • 59 Answers
Press shift + num lock and see if works. you should have a green led under the display. when press SHIFT + NUM LOCK , the green led state should change
Posted on Jul 19, 2009
  • Thomas Skeese Feb 19, 2011
    Thanks for the help .That was the only key I hadn't tried yet .Problem solved !
What is num lock and where it i located in the keyboard
Posted on Mar 13, 2010
'tab' button doesn't work on Motorola MC3190
You get 3 different keypad models of the Motorola MC3190:
- 28 Key Numeric
- 38 Key Shifted Alpha
- 48 Key Alpha Numeric
So depending on the type of keyboard your model has, using TAB are different across these 3 keypads.
Please Note: Keypad functions can be changed by an application so the mobile computer keypad may not function as described.
When the FUNC button is pressed the icon "F" appears on the taskbar on WinCE devices or the icon "Blue Circle" appears at the bottom of the screen on Windows Mobile 6.1 devices.
In order to use the TAB function, do the following:
28 Key Numeric - Press the blue FUNC button (Bottom right next to Power button), and press the RIGHT ARROW button.
38 Key Shifted Alpha - Press the blue FUNC button (Right side below RIGHT ARROW button), and press the RIGHT ARROW button.
48 Key Alpha Numeric - Press the blue FUNC button (Right side below ENTER button) and press the number 9 button.
Apr 18, 2014 | Zebra Symbol MC3190G Handheld Mobile...
Advent 9517 several letter keys bring up numbers
Touch Freeze, a free utility program may help fix that problem. I assume this just started to happen, correct?
If that fails, try another keyboard, preferably a USB Wireless Mouse/Keyboard.
Jan 08, 2014 | Computers & Internet
How do i get numbers from my key pad as well as letters?
Your NUMBER pad is down in left corner where it has ABC KEY.
It has a ?123 key. Hit it and the alpha keypad will change to numbers.
chad man
Nov 16, 2013 | Acer Iconia B1 7-Inch Tablet Black Dual...
Acer laptop number keys on right not working.
You have hit the num lock key. Lookin at pictures I could find on the internet, the Num Lock key is next to the backspace key, and above the number 7 key.
Hope this helps
Mar 30, 2012 | Acer Aspire Computers & Internet
How do I find the standard deviation?
Here is a detailed exemple. Hope it helps.
Some comments on the various variables (should the information be needed. If not need, please skip it.)
1.All you have to do is follow the instructions key stroke for key stoke, but enter your own data.
2. If a number is repeated 3 times like the number 55, you can enter it 3 times or use the shortcut in the exemple
55 [2nd][FREQ]3 [Sigma+].
3.If you make a mistake and enter the wrong number, use the [Sigma-] key to remove it. That is similar to what a cashier does when an item is entered twice: it is entered a third time but with minus sign.
4. Every time an item is entered, the display shows the total number of items so far. When it is finished the cashier press the key that sums up the prices to get the total. This is the role of the [2nd][Sigma X] key combination.
5. The average number of the data is obtained by the [2nd][x bar] combination. The last two key combinations display the two type of deviations.
Check the theory you have been taught and try again. If that is not the type of statistics you were supposed to do, then give more information.
Oct 28, 2009 | Texas Instruments TI-30XA Calculator
No dial tone with 3730
No dial tone means the terminal is not getting a signal from the phone line.
Troubleshooting:
1) Make sure it is not on a splitter most of time the splitter goes bad.
2) Make sure the phone cord used is a 2 pin cord.
3) Make sure if you have DSL from your phone company plug it in a DSL filter but make sure
you drop the baud rate the terminal uses.
Hit the more key (2nd purple key from left usually the tip key) until you see other setup.
Enter Password Default 1 Alpha Alpha 66831 Alpha key is the little black button above
the number 2.
Then hit the more key again until you see COMMS choose that and hit next until you see
Baud rate. Hit Edit and then NEXT until you get 300 baud when that shows under new hit
select or enter. Choose F4 exit save changes and then the red X key until you are back at
main sales screen Run a test sale.
If still same problem Repeat steps and change baud rate until one works. Usually 300 will
work for DSL lines.
Call me if you need assistance.
www.greenlightpayments.com EXT 105
Jul 02, 2009 | VeriFone Omni 3700
Having trouble entering wep key for wireless printing. It is stuck on alpha and wont't do numbers. (J4680)
As you press the keys it will cycle thru the small letters first then the capital of the same letters then numbers just take your time and you will get it to go to the numbers.
Mar 28, 2009 | HP Officejet J4680 InkJet Printer
Keyboard Fn appears to be stuck
check to see if the num lock key is on
Nov 22, 2008 | Dell Inspiron 1501 Notebook
Minutes
Yes. Use the following procedure to enter an angle in degrees-minutes-seconds form:
Enter the number of degrees. Press "2ND" "ANGLE" "1"
Enter the number of minutes. Press "2ND" "ANGLE" "2"
Enter the number of minutes. Press "ALPHA" " (double-quote above the +)
The ANGLE key is the APPS key.
Aug 19, 2008 | Texas Instruments TI-84 Plus Calculator
Verifone omni 3750
System password is universal UNLESS your merchant account provider has changed it to their own internal one.
Universal is 1 then the little black alpha key above number 2. Hit that Alpha key twice it will look like nothing happens but that one just changed to a z. then 66831 and enter that is the system password.
So 1 ALPHA ALPHA 66831 and then the enter key.
too run the terminal in offine or store & forward mode your account provider needs to enable it for you if it is enabled try this first. At the main sale screen:
Hit number 2 by itself if it says batch ayth or store & forward turn it on then you are in offline mode meaning it will not dial out for Authorizations. You must however when you get to a phone line you must hit settlement and it says you have offline trnasactions do you wish to upload choose yes. Each trans ran in offline mode will get a live approval and then when all is approved you will get a settlement report.
PLEASE YOU ARE TAKING FULL RESPONSIBILTY IF THAT CARD IS NOT A GOOD CARD DECLINES/FRAUDS IS ALL THE MERCHANTS RESPONSIBILTY.
Jul 01, 2008 | VeriFone (M19755014US1) Magnetic Card...
IBM Thinkpad 560 Series Laptop 20h4241 Keyboard Logo
2,581 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
