Why does my keyboard not work right. Some of the keys don't respond when I am typing. Have to go back and press them harder to make them work.
    Sniper:
  • 59 Answers
Here is the solution. you have to get needle and cottonwool, with surgical sprit. you can remove key following guide i'm giving.
http://www.youtube.com/watch?v=gKzbyJgsivc
after insert needle between two transparansis. apply some surgical using cotton wool. use tweeser for that. clean carefully. without damaging to the conducting path. i have tested several time. 100% suceed.
Posted on Jul 19, 2009
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    Ti89 responds to resets but nothing else
    If the calculator is several years old it may be showing its age.
    There is a connection point between the keyboard and the display
    that over time loses its efficiency. Try this: press a number key
    and at the same time apply pressure with your thumb or index
    finger to the region of the calculator just below the display.
    If you press hard, the number may just show up in the display.
    This is a test for the tightness (or electrical efficiency) of the
    keyboard-to-display connections.
    Another way to make this test is to twist the calculator while
    you depress a number key.
    Sometimes the effect is such that the keys on one side or the
    other work, or don't work, and the keys in the middle don't work
    or work okay. By twisting (don't break it!) the calculator body
    while you press the keys will show the weakness of the
    connector between the display and the keyboard.
    This can be repaired by a good electronic technician if you
    explain to him what I just told you.
    Aug 29, 2011 | Texas Instruments TI-89 Calculator
    The letter Z key is not responding. I don't know how to fix it
    Although having a laptop is certainly convenient, the all-in-one peripheral scheme (mouse, keyboard and speakers) can make individual repairs difficult, and a non-working keyboard can ruin the value of the entire package. However, there are some practical steps you can take to fix a laptop keyboard.
    1.Diagnose the problem. When you press a key on your laptop keyboard, does it get stuck? Does the computer respond to your inputs? In almost all of these cases, the solution will lie in opening up your notebook's keyboard. However, to prevent extra work, press every key (do this in a word-processing program) and see which keys are affected. If every single key on a keyboard does not respond, you might have a software issue, which may require specialized help.
    2.Clean the area around the keys that are not working. A damp lint-free cloth should be used to clean the surface of the affected keys. If you have stuck keys, use a Q-tip to clean under them, but take care not to pry the keys up, as this could result in further damage to your keyboard.
    3.Remove the keys that are not working. Do this by grabbing some fingernail clippers and pulling out the hook-like fingernail cleaner extension. Use the small hook to gently pull the key up , which will expose a collapsible plastic hinge (commonly known as a key retainer) as well as a small rubber circular piece. Gently lift both of these pieces out of the keyboard.
    4.Wipe the keyboard sensors clean with a dry cloth. The sensors are the little silver foil-like strips you see after your key components have been removed. Be very careful wiping these down--if they are damaged, they are very expensive to replace. Just gently dab it with a dry lint-free cloth to remove any dust/crumbs/particles that are interfering with your keyboard's functionality. Do not moisten the cloth with water or cleaning solution, as this heightens the risk for damage.
    5.Reassemble and replace the keys. Simply fit the key retainer as well the little rubber piece together in the way you found them and then firmly press the key cap back in place.
    6.Test your keyboard. Open a word-processing program and then press the replaced keys. If they still don't work, try restarting your computer, or activating a system restore point (to ensure that the problem is not software-related). If the keyboard is still not working, then you may want to think about taking the computer to a repair shop or replacing it altogether. (Keyboard repairs are very expensive.)
    Thanks.
    Aug 25, 2011 | Dell Inspiron E1505 Notebook
    Im using my mom Dell latitude D600 PC Laptop and It was working good then all of sudden S key wont Stop typing itself Till we press "r or T" it making it hard when it pops up out the blue. it...
    It seems that your laptop keyboard is not working any more. you need to buy new keyboard for ur laptop or if you want to use usb keyboard then remove this keyboard's cable, connect your usb keyboard it will work.
    Aug 21, 2011 | Dell Latitude D600 Notebook
    HP G60-235DX keyboard not working at all
    Try to press Fn + Num Lock or Fn + Scrl lock to check if they keyboard will respond. If it doesnt. try to turn off the computer, remove the cables and battery, press/hold the power button for 8 secs. Reinsert cables and battery then turn on the pc. Press again Fn + Num Lock or Fn + Scrl lock. If the keyboard still did not respond, go to the device manager . Click Start > right click My Computer > Properties > Hardware > Device Manager . Then click the (+) on Keyboards, right click the device and uninstall it. Then, go back to the device manager and right click Keyboard then click Scan for hardware changes. Then press FN + Num Lock or Fn + Scrl lock. If symptom persists, call HP to replace your keyboard.
    Aug 22, 2010 | HP G60-235DX Notebook
    2 letters get typed while pressing one key for some characters. There are some keys in pairs in which if i type any of the key, both the letters gets typed. i.e. if I type s, sd gets typed or evens if I...
    try other keyboard if the problem don't appear that's hardware problem, may be the rubber under the key responding each other, it is easy to open the keyboard casing then you can check the problem inside
    May 13, 2010 | Computers & Internet
    Carriage wont respond
    Perhaps the L. Mar. is set there. Turn it on wait for the por sequence to complete, touch the mar rel key, back space to the far left, press L. mar key. If that dosen't do it tou must have some lights flashing and/or beeping, What lights and how many beeps?
    DickyO
    Feb 26, 2010 | Lexmark Wheelwriter 10 Series II...
    Acer aspire 3003wcli keyboard stopped responding
    You probably activated the "Num Lock" accidently. Just hold down the FN and look for the key that says "num lock" Now you should have your keyboard back and the numbers will just type when you hit the numbers key. I did this to myself yesterday!
    Dec 06, 2008 | Computers & Internet
    Keyboard not responding or typing random letters
    You have stuck keys from when you removed to clean. Remove the stuck keys and see if it works OK when you press the rubber cap instead of key
    The back space one may have a link under it if it is a wide one ensure it is fitted correctly
    Aug 09, 2008 | HP P2360AA Keyboard/Mouse
    Laptop will not respond
    It sounds to me that you may have an issue with the keyboard itself, as most BIOS will stop on a keyboard error unless told otherwise. But, this could be a malfunctioning keyboard, or a disconnected keyboard. 1 way to test either is to press the caps lock, num lock or scroll lock keys and verifying the corresponding light turns on and off with the button presses. If they do not respond, it's likely the keyboard has become disconnected internally. Other issues may also cause this to happen, but they are harder to test for. If it does respond, then it's more likely to be a keyboard failure, and a replacement of the keyboard may be required.
    Hope this helps!
    -Backu
    Jan 16, 2008 | HP Pavilion ze2000 Notebook
    Computers & Internet Logo
    140 people viewed this question
    David Payne
    David Payne
