Question about Cell Phones
Can't assign media as ringtone in lg banter moving them from other phone razor but can't assign them on lg banter
Cant assign ringtone on rumor touch
Well, after you decide to make a song a ringtone, simply press set as and you'll see options such as ringtone,individual ringtone..etc.If you don't see the set as button, try press options,set as..etc.
I hope this helps your problem!
May 31, 2010 | LG Cell Phones
How to transfer Motorola Razor V default ringtones
you can transfer it from your computer with the ring tones saved on the system,or via mms message sending ring tone form razor to your lg phone aso you can use blue tooyh to transfer ring tones
Dec 18, 2009 | Motorola Mobility RAZR V3
How do I assign ringtones to particular people? Thanks
select a particular contact,go to options and then select 'assign ring tone' and then assign the desired ringtones.
Dec 04, 2009 | LG Vu CU920 Cellular Phone
How do i assign individual ringtones to my lg km380 cellphone
Follow the path: (1) Menu_Contacts search for the contact you want to assign a ringtone. Select "Options", you will get a Menu containing option "Edit". Select it and you can add or edit a ringtone to the specific contact.
(2)You probably wont get option to assign ringtones, if the contact is saved to your sim. So first u got to transfer the contact to you phone memory. This is how. Just go to Menu_Contact and search for the contact and press edit, you will get a option "Copy to phone". Select it and copy it to the phone memory. Once copied you can edit the ringtones by following the steps as in (1)
Apr 30, 2009 | LG KM380 Music Phone (Black)
Downloading a ringtone to my phone
in motorola v3 razr ringtones get downloaded in the phone memory and doesnot go to the card memory . so you need to switch the memory to the phone memory and then you will be able to see that ringtone. once you move that ringtone to the card memory and then you can assign the ringtone also .
If you want ot assign the ringtone to some particular contact then it should be in the phone memory then only it wil pick up that not from the card .
Mar 26, 2009 | Motorola Mobility RAZR V3
Trying to assign ring tones to person
first the person should be in your phone memory contact list not the memory card/sim card
second copy the song to the phone memory
and then go into the phonebook select the contact and edit it and there you will find the option for assigning a ringtone.
Mar 23, 2009 | Cell Phones
Lg lx260
ringtones save to the phone memory, not the micro SD
Nov 09, 2008 | LG Rumor LX260 Cellular Phone
Caller ringtones on LG shine
you need to save your contacts to the phone not the sim card.
Oct 12, 2008 | LG Shine KE970 Cellular Phone
RAZOR 2 RINGTONES
Use Master Reset option Its get reset your phone
you also use Master clear option , all your phone data get erased
and also ring tone
Feb 02, 2008 | Motorola Mobility RAZR V3
Different ring tones for different Contacts
I don't know how you can assign pics/music to sim contacts - I tried but I couldn't work it out as well. When I click 'edit' on a sim stored contact a menu appears with memory, name and number only.
However, if you move your contacts from sim to phone, you will be able to assign both pictures and ringtones. This time the edit menu extends to home, mobile and office number, e-mail, group, ringtone and photo (with photos make sure size is 680x480 or smaller).
Dec 10, 2007 | LG Prada KE850 Cellular Phone
Cell Phones Logo
924 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
