Question about Troy Garden
Troy Bilt model series V560
Initially, while mowing the grass we heard a snap. The lawnmower self propeled wheels stopped working. We attempted to take off the belt to see if that was the problem. Now the lawn mower will not start after putting back together. We notice that there is now slack in the contol cable. Can anyone help us get this back together. We did order a new variable speed cable, but have no idea how we are going to replace this.
4 Suggested Answers
landsend
  • 1066 Answers
SOURCE: Troy Bilt Self Propelled Lawnmower drive belt
belts usually come off for a few reasons.
They become loose...stretch or the tensioner moves,  Make sure that none of the tightening bolds are slipping.  You can dab them with a bit of paint.
when the pulleys are not in alignment or crooked or bent.  Eyeball the path from one pulley to another, also make sure the tensioner is in alignment and there are no other obstructions.
good, high quality belts are required, and they must be real drive belts...not regular v belts.  If there is a way to watch the belt in operation you can usually see what's going wrong.
On my lawnmower I had to grind some metal away where the belt went from the motor to the transmission.  Good luck
Posted on Apr 18, 2009
vincob
  • 718 Answers
SOURCE: variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Posted on Jul 26, 2010
SOURCE: Own a Troy Bilt self-propelled model #12A-466-M011
I had the same problem with my Troy-Bilt self propelled lawn mower. You have to use the grass catcher if your grass is high. Also, I mowed wet grass and it made my belt slip off the pulley and created a new problem, somowing wet grass is definitely not a good idea.
Posted on Aug 05, 2010
Troy Bilt XP self propelled mower
Normally an indication of poor air flow. Replace air filter. Clean outside of carb with carb cleaned to ensure choke is free to operate. Go real slow in tall grass, some mowers don't have the torque to do tall grass, only use 1/2 of the deck width and have side discharge open.
May 10, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 675 Series manual
Try internet search w/full detail like you used in question plus specifics like model number. That worked for me w/my lawnmower manual search.
Jul 09, 2012 | Garden
Own a Troy Bilt self-propelled model #12A-466-M011 for a year now. It worked great when first got it. Now it will not clear the grass underneath so cuts off every 15 feet and have to manually clear grass...
Aug 01, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Variable speed doesn't work troy bilt self propelled lawnmower
Jul 26, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Self propelled stops working well mowing, I
turn it off,let the drive handle go,pull mower backwards.does it lock the back wheels?if you push it forward,can you hear a clicking noise from the wheels?you should do.lift mower,spin back wheel,should either lock,or click,depending which way you spin it.they have spring loaded pawls that drive the wheel.usually easy to fix.usually dirt,or too much grease.take wheels off,have a look
Jul 04, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt mower self propelled 21". Belt has come off
Take the three screws out of the belt cover. One screw in behind each back wheel. The other is under the mower near the shaft to blade. Remove the tension spring off the transmission. Then remove blade and the cover comes off. You then can put the belt back on. Sounds like fun don't it!
Jun 13, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
ROPE ON MOWER WON'T PULL OUT
I agree, it sounds like the mower is fouled with foliage at the blade. Pull off the spark plug wire and tilt the mower on its side opposite of the carburetor, check the underside of the mower for impacted grass clippings.
Apr 30, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Model Series 860
sounds like a bad tranny if this unit is under warentty DO NOT ATTEMPT REPAIR . if you attempt to repair this yourself you can void any warrenty
Sep 19, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
647 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
