How can I fix my phone settings to enable forwarding pictures via messaging via Cricket wireless? I have contacted Cricket and have the correct sms/mms settings for the phone but I still cannot send images via text messaging. Cricket was unable to come up with a solution. I have the 2.5 GB plan. Could this be the problem?
SOURCE: RAZR V3 is sending my text messages as SMS messages
Motorola website has a delightful fix for this problem. http://motorola-global-eng.custhelp.com/cgi-bin/motorola_global_eng.cfg/php/enduser/std_adp.php?p_faqid=4627&p_created=1180712973&p_sid=rxo1DDHi&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTUmcF9wcm9kcz0zMCwyNjI3LDY2OSwxMTgwJnBfY2F0cz0mcF9wdj00LjExODAmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1DZWxsIFBob25lcyAvIE1vYmlsZSBEZXZpY2Vz&p_li=&p_topview=1
SOURCE: Phone Sending MMS Messages as Default
The phone allocates a certain amount of storage for messages on a whole. Even though there may still show space available for text messages, you have hit an invisible "limit" and the phone is now defaulting to MMS messages because there is "room" there. Delete a fair amount of messages and you should be able to start sending regular text's again.
SOURCE: Samsung U600- WAP and MMS settings for T-Mobile
I have had a similar problem when I first got my unlocked phone. I have T-mobile as well, and once they find out you have a phone device not purchased by them, they are not very helpful - they will give you their default mms settings(same ones listed on their site). I tried those settings and they did not work on the particular unlocked phone I had. I did some extensive web searching and came across a few settings that worked with my phone. I will list them here. Hope they work for you!
*MMS Settings: Home URL - http://216.155.174.84/servlets/mms
*Protocol Type - WAP
*WAP IP Address - 216.155.165.50
*GPRS Access Point - wap.voicestream.com
*GPRS Username - Leave Blank
*GPRS Password - Leave Blank
*Authentication Type - normal
*T Zones - http://wap.myvoicestream.com
SOURCE: MOTOROLA KRZR KM1
to fix this problem you will need to contact your network service provider and get them to resend your gprs settings to your handset, this will than allow you to use the requested features on your mobile phone, because it sounds to me as though, either the gprs settings have not been set up or they have been deleted, hope this helps.
SOURCE: I have a cect n97c and i can't seem to get the
Create Data Account
3. Select Services
4. Select Data Account
5. Select GPRS
6. Choose an empty profile
7. Account Name enter T-Mobile WAP
8. Press Options
9. Press Done
10. APN enter wap.voicestream.com
11. Press Options
12. Press Done
13. User Name >Leave Blank<
14. Password >Leave Blank<
15. Auth. Type choose Normal
16. Press Done
17. Press Save
T-Mobile MMS
Create Profile
3. Select Services
4. Select WAP
5. Select Setting
6. Select Edit Profile
7. Select a profile
8. Choose Edit Profile
9. Rename Profile enter T-Mobile WAP
10. Homepage enter wap.myvoicestream.com
11. Data Account select GPRS
12. Select T-Mobile WAP
13. Connection Type select HTTP
14. Proxy Address enter 216.155.165.050
15. Port enter 8080
16. User Name >Leave Blank<
17. Password >Leave Blank<
18. Press Done
19. When prompted to SAVE please select Yes
20. Select Activate Profile
21. When prompted to Activate Profile please choose Yes
22. Press Done
Create Data Account
3. Select Services
5. Select GPRS
8. Press Options
9. Press Done
11. Press Options
12. Press Done
16. Press Done
17. Press Save
Create Profile
3. Select Messages
4. Select MMS
5. Select Message Setting
6. Select Server Profile
7. Select a Profile
8. Select Edit Profile
9. Select a profile
10. Choose Edit Profile
11. Rename Profile enter T-Mobile MMS
12. Homepage enter http://216.155.174.84/servlets/mms
13. Press Options
14. Press Done
15. Data Account select GPRS
16. Select T-Mobile WAP
17. Connection Type select HTTP
18. Proxy Address enter 216.155.165.050
19. Port enter 8080
20. User Name >Leave Blank<
21. Password >Leave Blank<
22. Press Done
Reboot your phone
this should work i had the same problem
