Question about Orion Televison & Video
I have a 27" TVD2710 - Orion. Have AT&T cable. TV has developed lines across the top, you can see thru them but they are about down to a persons forhead on screen. Now, the set works for about 2hrs, then goes down and you have to reload. Also, the sound is not consistent. Can someone tell me what is happening and can they walk me thru steps to correct?
  • 580 Answers
Replace the vertical IC, the 100 microfarad-50 volt capacitor near it, the supply diode and resistor and your all set. If you have not done a TV repair yourself before I would recommend a shop replace the vertical IC
Posted on Jul 19, 2009
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
Is this TV digital ready, or do we need a converter box?
No, it is not a digital ready television. You will need a box if you are planning on using an antenna with it.
If you have it hooked up to cable or a satilite reciever then you don't need a box. It will continue to work like it is now.
Jan 24, 2009 | Orion Televison & Video
Hook up DVD
I hooked up my DVD player to the Yellow/Red/White inputs on the back of the set. I think you can buy a manual for $2.60 from the Orion website. Good luck.
Jan 05, 2009 | Orion STV2763 27" TV
Line across the screen
dry joints on the field output ic is a fairly common problem with these.if a firm slap changes things,a simple resoldering job does the trick.resoldering is usually the cure ir the fault was intermittent.otherwise the ic may need to be replaced.cheap as chips,so to speak.hope this helps,steve.
Nov 05, 2008 | Orion STV2763 27" TV
Sansui DFTV275
It is very common in many sets of this type that the electrolytic capacitors in the vertical deflection amp section start to go high in their ESR values.
An experienced TV tech can determine the defective capacitors and change them for you.
Jerry G.
Jun 25, 2008 | Orion STV2763 27" TV
Picture problems
Bad electrolytic cap(s) in vertical deflection section.
Nov 21, 2007 | Orion STV2763 27" TV
Orion FTDV 2004 Dead Set
Question, when I clicked on this I clicked on a problem for a Sony KV27S10 but your text say's Orion, is it a Sony or a Orion?
Aug 18, 2007 | Sony KV-27S10 27" TV
Orion 27" tv
hi your problem could be two different things , the first one is that it mught have a cold solder in the vertical or a bad capacitor in the same area.
Nov 02, 2006 | Orion STV2763 27" TV
Televison & Video Logo
19 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
