Question about Kitchen Ranges
Frigidaire gas range model fgf353cata
Oven cooks for about 20 min. then shuts off automatically.
  • wagner360 Nov 19, 2007
  • 4,102 Answers
Hi this is deffinately a problem with the thermostat and will need replacing what is happening is you are setting the temperature you want on the oven and then when the oven gets upto temperature it should tell the oven this is the right temp and cut down the gas supply to keep the oven at set temperature but when the thermostat fails the temperatur goes above the setting you choose so it cuts itself off as a safety feature to stop it setting fire to anything in the oven most cookers are set to do this so you could either source the part yourself and fit yourself but if you are not confident in working with or on gas appliances then i suggest you call someone out this is a relitively cheap repair so call someone out tell them what wrong and they will source part and replace it for you should only take a couple of days to get part but if you use a registered repair firm they should carry the part in stock as this is a common fault with most ovens hope this easis your mind a bit if you want to do it yourself you will nedd to get a manuall covering your unit for repairs but if unsure what you are doing leave it to pro as if you get it wrong you could spend more money where as if you call someone out they no what they are doing and should give you a warranty on the part and repair so this would be the best option hope this is some help to you good luck
Posted on Nov 19, 2007
  • paul proctor Nov 19, 2007
    it could be the sensor that has gone you should be able to replace these yourself but make sure you get the right part for your model no you could try replacing this yoursellf as the first thing to do but without proper testing equipment you wont know which part has gone or not the sensor is the cheapest of the two and can sometimes solve the problem but i would try this first as it is the cheapest option you should be able to do this yourself hope this is some help to you you should be able to download a service manuall off the net just use a good search engine to find one on finding one this will give you step by step details how to go about the repair i will have a look for you and if i come across one i will post you back the details ok good luck
The oven turns its self ON every 20 to 45 mins. The electric ignition glows and the gas comes on and burns for about 30 to 60 secs then turns off. The oven control knob is turned OFF. There are no aut
Seems to me you have a defective control panel board.. Ovens should never do this. Time for the Serviceman right away, this could be dangerous if you are not home.
Nov 24, 2014 | GE Kitchen Ranges
Gas does not come on for oven to light
im assuming that your cook top works fine and that the broil is working fine. You need to replace the oven ignitor. The automatic gas valve is equipped with a sensor that opens the valve. if the ignitor doesn't heat up the sensor, then the valve will not open. replacing your ignitor should solve the problem.
Feb 06, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Ignitiors just keep igniting wont stop after finished cooking about 20 min
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
Sep 08, 2010 | Frigidaire FGF334BG Kitchen Range
Microware shutoff after ~4 min of cooking
Return it for warranty repair or replacement. Does the blower motor operate?
Sep 08, 2009 | Maytag MMV1153A Microwave Oven
Electrical fire in stove
I would call the gas company and have it checked out in case you had a gas leak on the stove which may have brunt the wires , it safe with the gas and elec off,
Jan 04, 2009 | Frigidaire FGF326AS Gas Kitchen Range
When we cook in the oven it says F2 every 10 mins.
This means that your oven temp sensor has failed. There is no way to fix the sensor. You have to replace. The f2 means that your oven has reached its heaeting limit and it shuts down for safety. Replace oven temp sensor and it wil fix it.
Nov 18, 2008 | Hotpoint RGB745 Gas Kitchen Range
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Gas oven temp problem
HI thanks for your question. there is a oven sensor , located in the oven, top left corner. replace this part. thanks the appliance doc. please rate my answer. thanks
Oct 11, 2008 | Frigidaire Ovens
Frigidaire cooktop
Hi Bobbiflower,
Happy to help you!
Go online to www.Frigidaire .com and you can enter your model # and download the manual.
if you can not locate the answer in the book,
I think that this problem will be solved only by service!
A & E factory service is good and nation wide!
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Jul 17, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire gas range FGF337
The Frigidaire units have a shutoff valve on the regulator that has to be flipped up so the oven will get gas.
May 19, 2008 | Frigidaire FGF337 Dual Fuel (Electric and...
Kitchen Ranges Logo
99 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
