Question about GPS
Inability to create a tracked and cornered identified area of approximatly 200mts square. I am getting totally lost in the setup ctiteria to enable me to map on the machine for eventual print out on the computer. Please suply step by step instruction on how to do this
  • 6 more comments
  • annemillar Jul 19, 2009
    it is a GARMIN GPS 60 Navigator
    how does this work do you send me more emails or what.
    It is for my husband Eric and we live in Korumburra ictoria Australia
    I meant Victoria
    I have a owners manual .
    What im trying to do is and this is an example.
    Walk around a block, and mark the corner points and then bring back to the computer a dotted square with indicated dotted points (corners). I am typing what he says, I hope it makes sense
    that will do for now. Eric is studing the manual. Thanks for yoour help
  • 13,433 Answers
Please use the add a comment link below to send me the brand and model of your device.
Thanks
Posted on Jul 19, 2009
  • Ekse Jul 19, 2009
    Yeah, thats how it works.
    Here is the user manual for the gps
    http://www8.garmin.com/manuals/GPS60_Own...
    I can't seem to find what your trying to accomplish with it from the documents.
    have a look and see if you can find what your looking for.
  • Ekse Jul 19, 2009
    I see, thats on page 29 to 38.
    Use the tracklog to do so.
What is the pyramid total surface formula
A pyramid has 5 sides including the base. If the base is a rectangle L long and W wide, its area is L*W.
The other sides are triangles. If the height of the pyramid is H, the triangles that are L wide at the base will have a height of the square root of half of W squared plus H squared, or SQRT((.5*W)^2+H^2) and the two that are W wide at the base will have a height of SQRT((.5*L)^2+H^2). The area of a triangle is .5*height*base, so the total surface two triangles with the same height and base is 2*.5*height*base = height*base.
So, the total surface area of a pyramid L long by W wide by H tall would be:
L*W (the area of the base)
+ L*SQRT((.5*W)^2+H^2) (the area of the 2 triangles with base L)
+ W*SQRT((.5*L)^2+H^2) (the area of the 2 triangles with base W)
Hope this is helpful!
May 23, 2014 | Encore Math Advantage Algebra II and...
I want to know the total sq foot of a 16'x14' room the total of a 14'x5' and a total of a13'x13' room Or the total of all 3 together. Thanks
If you have a calculator just turn it on and typ[ what follows.
[X] means you press the multiplication key
[=] means you press the = key
[+] means you press the addition key (plus)
16 [x]14 [=] area of first room.in square feet
14[X]5[=] area of second room.in square feet
13[X] 13= area of third room in square feet
If you want to obtain the total area of all the rooms at one go
16 [x]14 [+] 14[X]5 [+]13[X]13 [=]
Aug 25, 2011 | Office Equipment & Supplies
A window glass 4 ft. 2 in. by 2 ft 10in. find its area. show the figure
Below is calculation of window glass area :
4.167 ft '------------------------------------'- ' ' ' ' 2.833 ft ' ' '------------------------------------'--
Total area = 4.167 ft x 2.833 ft = 11.81 ft2
Dec 04, 2010 | CRL Fixed "All Glass Look" Window for Side...
I have a 16' x 16' building to put up what is the diagonal so I can keep it square
to keep your building square you mark out with stakes 16 ft.all four corners,now the corner that you like thats in the area of choice,you have to measure corner to corner so that you have the same measurment then you will be square.
Mar 19, 2010 | Square M-D Building Products 27870 16X24...
Need to identify where paper sensors are in paper path. Can not clear paper jam. have totally cleared paper path removed all necessary parts even removed covers and blew machine off. also, sensor for over...
its probably exit sensor which is in the right hand corner just above fuser. hard to get to will need to remove fuser,front small square cover and prob exit cover ull see actuator and a long shaft which will lead u to a sensor.it will prob out of place or covered in dust.
Feb 24, 2010 | Ricoh Aficio 180 Laser Printer
I am totally lost!! All I have is the lambda lexicon and cubase LE4 on my desktop.Apparently it is not set up correctly. I want to record guitar and voice I have sound on lambda through mike and guitar but...
All it needs is a USB connection. You'll need to go into Cubase device setup and make sure your lambda drivers are selected. Then create the audio channels in cubase with the inputs set as the inputs you're using for guitar and mic. There is a monitor button right next to the record enable button that needs to be enabled if you want to hear playback from your computer.
Feb 20, 2010 | Lexicon Lambda Usb Desktop Recording...
Track lost HTC Diamond
Is your company on exchange 2007? and is your phone sync'd to it wirelessly?
You can allways deploy a GPS tracking tool to the phone if it hasn't been wiped.
I would suggest a tool that doesn't have much of a setup required and can be just "ran/installed"
Jun 29, 2009 | HTC TyTN II Smartphone
Hhow to save a pattern in fl studio and reuse the same in another
Open up the piano roll window for the sample you have selected. Use the highlight tool, which looks of a dashed square, to select the entire pattern by dragging your cursor from the top right corner of the piano roll diagonally to the left bottom corner of the piano roll. If you can't see all of the bars used, then try sizing the track in the piano roll closer together by placing your cursor on the square directly to the right of the horizontol scroll bar. Hold down the left click and move your mouse down to track the piano roll closer or move the mouse upwards to span it more. Select all of the bars used in the piano roll and click the down arrow in the very upright corner. Select Edit > Copy. This will copy all of the bars in the current piano roll. To paste the pattern simply click the down arrow again in the upright corner and select Edit > Paste in any piano roll.
Jan 20, 2009 | Image Line FL Studio 5 Producer Edition
Account Track disabled in Vista x64
With the newer driver (ours is 64bit), I did this by going to:
  • Printer Properties >>
  • Configure tab >>
  • In the Device Option area, scroll down to view Account Track >>
  • Select Account Track >>
  • Then, select Enable from the dropdown (in the Setting area).
  • Click OK
[Whew! Who wrote this dialog box, anyway?]
Jan 24, 2008 | Konica Minolta bizhub C250 All-In-One...
VPN
This example will demonstrate how to create a Virtual private Network (VPN) between two remote locations through the Internet. The VPN policy will use 3DES IPSec to securely send/receive encrypted data over the Internet. When the VPN tunnel is enabled, the two offices will virtually appear to be on the same local network. This example will consist of two DI-804V VPN Routers with a simple setup. The two remote offices in this example will be known as Office A and Office B. Both VPN Routers must already be set up and able to access each other. This is only an example, your setup will vary using the WAN IP address provided by your ISP. Please note the differences in the IP addresses for each office. We will begin by configuring the DI-804V at Office A. Start by going into VPN Settings under the Basic Setup menu. Step 1. In the Connection Name field, type in OfficeA. Click ADD. Step 2. A properties screen will appear for the new connection you have made. Fill in the appropriate information for Office A: Connection Name: OfficeA Local IPSEC Identifier: Local Remote IPSEC Identifier: Remote Remote IP Network: 192.168.1.0 Remote IP Netmask: 255.255.255.0 Remote Gateway IP: 192.170.0.2 Network Interface: WAN ETHERNET Secure Association: IKE Perfect Forward Secure: Enabled PreShared Key: 123456 Key Life: 28800 IKE Life Time: 3600 Step 3 Click SAVE. There should now be a VPN policy created for Office A. Now you will want to Save & Restart the DI-804V. Note: 123456 is an example of a preshared key, please fill in any secret preshared key you desire. Keep in mind that both sites require the same preshared key. Office A setup is now complete, we will now configure Office B with the other DI-804V, Follow the same steps previously with Ofice A to create a VPN policy. Step 1 Please change the appropriate information. Connection Name: OfficeB Local IPSEC Identifier: Local Remote IPSEC Identifier: Remote Remote IP Network: 192.168.0.0 Remote IP Netmask: 255.255.255.0 Remote Gateway IP: 192.170.0.1 Network Interface: WAN ETHERNET Secure Association: IKE Perfect Forward Secure: Enabled PreShared Key: 123456 Key Life: 28800 IKE Life Time: 3600 Step 2 Click SAVE. There should now be a VPN policy created for Office B. Now you will want to Save & Restart the DI-804V. After the VPN policies have been created for the two Offices, the two remote locations should authenticate and connect. To view the status of the VPN connection, go to the Device Status menu. On the bottom-left side of the menu, click on the VPN Status icon. A VPN Status pop-up screen will appear showing VPN connection status. If a VPN tunnel is active, the State should indicate Q-Estab. Go to a DOS prompt and ping the internal IP address of the remote network.
Feb 16, 2006 | D-Link DI 804V (DI-804V) Router
GPS Logo
21 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
