Question about Panasonic KX-TG5631 Cordless Phone
No digital display on handset and battery is fully charged. Checked battery with a voltmeter
Posted on Apr 19, 2010
  • 31 Answers
Pls check the display meter
Posted on Jul 19, 2009
I have a pride cirrus Wheelchair a voltmeter shows that the batteries are fully charged up. But when I drive I don’t get very far before the VSI shows of the batteries are dead. I check again at the...
faulty voltmeter and /or bad batteries
have the batteries load tested to eliminate them then replace the voltmeter
in reality it should be showing a reduction in volts available as the batteries run down form use
as an example
fully charged batteries 12 or 13 volts
go for a trip around the block and as you go the meter should start reading a lesser voltage as you are going or a reduced voltage at each stop
Nov 13, 2017 | Pride Health & Beauty
I have a vetch mod# CS6114 I checked the base unit and it gets power to charge phone but I can't get a dial tone. I even hooked up to another line and still won't work.
This sounds like a registration problem, the
handset must be de-registered from wherever
it thinks it is and then registered to your base.
( I ). First, to de-register a cs6114 handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll from "Test Base" to "Test Handset", press [select]
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( III.) To register the cs6114 handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
NOTE 2: Some cs6114 bases do not have the "In Use"
lamp indicator. To register the handset simply park it
displaying "Not Registered" in the base cradle and wait
for the registration to occur. Pressing # as above may
be required, maybe not.
Good luck !!
Feb 12, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
Replacement batteries do not seem to be charging. Have checked they are the right sort of batteries. What am I doing wrong!?
The assumption is you replaced the batteries because you thought they were bad. It's highly possible the charger of your base is dead. If you have a voltmeter see if there's voltage (10% or more greater than the rated voltage of the battery). If not, it's the charger that's dead, not the batteries.
Nov 29, 2014 | Lands Phones
Blackberry 9720 suddenly went dead wont charge
Hi Michelle. I have the same phone and it happened to me a few times. On most phones the battery swells up when it reaches it's charging life end. In the 9720 the battery can still LOOK okay even though it might have reached its life-span. I eventually purchased a new battery, and wholaa, problem solved. A piece of additional advice is: Do not chat with you phone on the charger. Unplug the charger when battery is fully charged: We tend to charge the phone anytime and every time before we go to work or somewhere - you have to let the battery run flat on its own at least once a month, then start a fresh charge from fully flat to fully charged. This will prolong battery life. I a new battery does not solve the problem, have the charging pin checked out. Alternately if you know someone that has the same handset as you, ask them to stick your battery into their handset and visa versa. Hope this info help :)
Aug 26, 2014 | Blackberry 9720 Smartphone White, Factory...
Battery doesn't charge
Shirley, check if you inserted the chip properly. Usually the bars are your wifi strength. Most likely its the chip.
Mar 02, 2014 | Panasonic Lands Phones
Battery light on and off
The battery light means the alternator is not charging the battery. The charging system would need to be checked out when the light is on.
Feb 07, 2014 | 2001 Pontiac Montana
My panasonic kx-tga520m cordless handset does not display caller id anymore. the second handset does display this feature. What should I do?
Because your phone was low on battery, you will not see this feature. Once you charge your phone fully, you will start receive phone calls and you will see this feature activating again.
Jan 18, 2010 | Panasonic KX-TGA520M Cordless Expansion...
Cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Apr 25, 2009 | Uniden DECT 6.0 Cordless Phone ID
I have a Panasonic KX-TG6051CM
I had the same problem, and it seems that the battery charging circuit in the handset had locked up, constantly charging the battery until it overheated. I was able to reset the circuit in my handset by completely draining the battery. Here is the procedure:
1. Remove the handset from the charging cradle, and leave it on for a few days until the battery runs out, and the handset finally turns off. At his point, the battery will be very low, BUT NOT COMPLETELY DRAINED.
2. Next, you must manually drain the charge remaining in the battery by shorting out the two contacts on it. Shorting won't damage the battery, since it is holding very little charge at this point. An easy way to physically do this is to remove the battery, and place a piece of thin wire across the the two contacts of the HANDSET. I am referring to the contacts inside the handset that connect to the battery, NOT the contacts on the bottom outside that connect the handset to the charging cradle. Next, put the battery back in, sandwiching the wire between the battery's contacts and those inside the handset. This will hold the wire in place. DO NOT PUT THE HANDSET BACK INTO THE CHARGER, WITH THE BATTERY SHORTED OUT.
3. Wait about 30 minutes for the battery to completely die. Remove the jumper wire, and but the handset back into the charger.
4. If the battery was fully discharged , you will get a message on the handset telling you that you should let it will charge for 7 hours. If you do not get this message, then either the battery was not fully discharged, or your problem is different from mine. Try the procedure again in Step 3 for another 30 minutes to discharge the battery some more.
5. If you get the "Wait for 7 hours to charge" message on the handset, then leave it in the charging cradle for the 7 hours requested. After that, it should work fine.
Let me know how you make out.
Mar 24, 2008 | Panasonic KX-TG6051M Cordless Phone
Panasonic KX-TG5631 Cordless Phone Logo
817 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
