Question about San d Digger
I have an old Ford 550 digger clutch failure
I have an old Ford 550 digger which has just had a hose replaced on the backhoe. On restarting the backhoe now works but I have lost operation of the clutch and can't therefore drive the digger with out crashing the gearbox. A warning light has illuminated to the right of the battery warning light. Does anyone know what this light is indicating. I don't recognise the icon. I suspect it is indicating low hydraulic fluid. Does this effect the clutch operation too?
  • Anonymous Mar 14, 2014
    Clutch slips
  • 850 Answers
If its a hydraulic clutch & conneted to the same system & its low on fluid then that will be your problem
just top it up & try it you may have to bleed out the system of air if it doesnt work!
Posted on Jul 20, 2009
Ford 555c backhoe want go foreward or backward out of fluid put fluid in still want go
Shuttle clutch? Might be burned up. Did you put a new filter on? don
Apr 05, 2017 | Ford Cars & Trucks
How to hook up the hoses when you replace them on a 1993 ford backhoe 555d rear boom
Label them one at a time when you remove them, take pictures, or just do them one at a time.
Dec 15, 2016 | Ford Cars & Trucks
1993 Ford 6610 S Tractor clutch problem.
if hydraulic system to work the clutch
bypass internally of master or slave or
system leaking
if a rod adjustment check free play of clutch fork
and pedal height
two types of clutch std or PTO dual clutch
dual clutches do have a higher failure rate
Jul 04, 2016 | Ford Cars & Trucks
Can you replace the push rod on the clutch slave with a longer one, I have a bent clutch fork.
This is a hard question to answer because you are driving with a damaged part and any Certified Mechanic would tell you that the clutch fork may be torn with metal failure.
There should be some adjustment, if not, you would first need to determine what length the rod would need to be to work.
Thinking "outside the box" there have to be alternate rods for trucks with lift kits. Raising the body off the frame must make changes to clutch components necessary. You may find what you want from businesses dealing with 4x4's and lift kits.
Jul 15, 2013 | 1999 Ford Super Duty F 550
550 ford backhoe troubleshooting manual
Use Standard solvent and blow out with compressed air or better yet replace the filter.
Aug 27, 2012 | Cars & Trucks
Truck has been running great,turned truck off , restarted it to notice a rough idle then check engine light came on, i had superchips flashpaq on truck ,got to repair shop had to re install ford stock file...
Are we talking about a 7.3L diesel? If so, I have seen all kinds of trouble started by people flashing their computers with superchips. You are better off with te OEM files in your computer. As for the injector, If we are in fact talking about a 7.3L, you probably need to replace your valve cover gasket. It contains the electrical wiring for the injectors. They like to burn at the connector going into the gasket. Not a cheap fix, either. (About $200 for parts)
Jan 11, 2011 | 1999 Ford Super Duty F 550
I would like to know the weight of a jcb 1400b backhoe
if it is standard clutch and the weight is 8,550lbs w/converter and 8,430lbs with dry clutch and if equip with extendahoe pwer shuttle is 9,210lbs and dry clutch is 9,090lbs and those weights do not include front or rear buckets of backhoe and loader as this can vary because of the size of bucket equip with. hope this will help you. jcmarleau@aol.com
Aug 29, 2009 | Bruder Mack Flatbed Truck with JCB Backhoe
How to remove the fan clutch on a 6.0 diesel
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Drain the cooling system.
  3. Remove the air cleaner assembly.
  4. Disconnect the radiator upper hose from the radiator. Position the radiator hose aside.
  5. Disconnect the overflow hose from the radiator.
  6. Disconnect the coolant degas bottle hose from the shroud.
  7. WARNING The clutch assembly nut has a right-hand thread and must be rotated counterclockwise to remove it.31a3ca2.gif
  8. 95f52a2.gifUsing the special tools, loosen the fan clutch.
  9. Carefully rotate the fan and fan clutch assembly counterclockwise until the assembly is free from the water pump. Place the fan and fan clutch into the shroud opening.
  10. If equipped, disconnect the retaining clips from the fan shroud.
  11. Raise and support the vehicle.
  12. Disconnect the lower radiator hose retaining clamp from the shroud.
  13. If equipped, disconnect the underbody splash shield from the shroud.
  14. Lower the vehicle.
  15. WARNING Use extreme care when removing or installing the fan, fan clutch and shroud. Failure to do so will cause damage to the radiator.
  16. Remove the mounting bolts, and the fan, fan clutch and shroud.
  17. To install, reverse the removal procedure. Install an appropriately sized worm drive-type clamp in place of the constant tension clamp. Observe the tightening torques shown in the accompanying illustrations.
Jun 20, 2009 | 2005 Ford E-Series
San d Digger Logo
764 people viewed this question
Top San Toys Experts
Adam Fjeld
Adam Fjeld
Andrew Taylor
Andrew Taylor
Are you a San Toy Expert? Answer questions, earn points and help others
