Question about Teac (CDW552GA02) (CDW552GA02/10PK) CD-RW/DVD-ROM (Combo) Burner
Why display "disk full" or "Wrong disk" and the disk is new
In win Xp displays "wrong disk" or "disk full" or insert a "writeable dik", but the disc is new, I can´t write in any disc.
I install the device again and the problem persist.
Thank You
Re: why display "disk full" or "Wrong disk" and the disk...
NOT SOLVED! i got the same problem... i used cd of nero it came worked with 1st comp now wont work with new comp....had another cd of nero from another dvd+rw/cd+rw that my sister brought and same problem
Posted on Aug 14, 2008
  • 244 Answers
Try to used Nero, application that will help your driver execute the appropriate task to execute.
Please rate me SOLVED
Posted on Nov 20, 2007
0 characters
3 Points
Hp w1858 computer monitor
That error indicates the burner doesn't think you have a blank CD-R in the drive. Check that you do!
Jul 08, 2014 | HP CD & DVD Burners
Just bought from a LG CH10LS20 bluray player; installed it on a Windows XP - it reads all dvd, but not bluray; i tested it on a windows 7 and everything is great. the error on win XP is: "windows...
Hello there,
you are right, Win Xp is not Blu-Ray compatible unless you installed UDF reader. UDF reader is a driver which lets you explore Blu-ray and HD-DVD UDF v2.5 disc in Win XP's file explorer.
Click the Link to download UDF v2.5 driver
1. After downloading extract the file to any folder.
2. Right click on thdudf.inf and choose Install.
3. Once this is done, reboot your machine.
4. After reboot your system will be able to read the new UDF 2.5 file system recognition.
5. If you want your system to read video files, you have to download codecs.
Codec Link download.
Thank you for using FixYa.
Hopefully this information helps.
Jul 27, 2011 | LG Electronics CH10LS20 LightScribe 10x...
My lg DVD RAM GH22NS50 is reading initially and hangs for some sometime and the DVD ram disappear fro my Computer.Again after removing the CD re start the computer it will appear.My OS is XP.I'm using a...
Hello, the problem is from the cd you inserted into the dvd rom, so it mean nothing is wrong with your DVD ROM. I think what you can do to make the DVD or CD work some how, is to use a dusting powder to clean it and try again. But thier is nothing wrong with your DVD ROM. Please vote me.
Mar 27, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
Hi it wont write dvds at all keeps saying insert a writeable disc
hello Is it registering music discs if not the problem is with your cd lens and will need to be replaced
Mar 24, 2011 | CD & DVD Burners
I have tried to transfer photo's onto an imation DVD+R (x8) using my Pioneer DVD RW DVR-107D . It says the disk is full or not writeable .This is a new disk and has nothing on it. What can I do to transfer...
That depends on the burning software that you have used. The easiest solution is to use another one and try again.
I use
Dec 04, 2009 | Pioneer DVR-107D DVD±RW Burner
Cd burner saysinsert a blank disc, even after I do, can't burn cd
The disc must not be compatible. Check the manual for compatible disc list.
Nov 23, 2009 | Pacific Digital X-treme 52 (TREME52)...
? Sony VAIO - PCG-GR390 ? Changed hard disk, ? Application & system recovery CD not working, its worn out. ? Installed retail ver of Windows XP ser.pack-2 ? Modem, display, LCD drivers not...
if your disk is worn you have to buy a new one from sony with the original software on it. there is no other option
san diago rrc
16550 via esterillo
building 5
door two
san diego california 92127
May 14, 2009 | Sony (PCGA-RDVG1) for VAIO PCG-GR300,...
Get into boot setup and change the 1st boot device as hard disk
Dec 30, 2007 | CD & DVD Burners
Rewrittable drive reads diks as wrong types
yep Drive is shot
I'd recommended you try upgrading the firmware or using a different media before buying a new one
Dec 24, 2007 | NEC ND-6750A DVD RW Dual Layer Burner
Teac (CDW552GA02) (CDW552GA02/10PK) CD-RW/DVD-ROM (Combo) Burner Logo
102 people viewed this question
Top Teac CD & DVD Burners Experts
Brian Sullivan
Brian Sullivan
Are you a Teac CD and DVD Burner Expert? Answer questions, earn points and help others
