Had an f05 fault on an indesit wixe 127 which apparently is the filter blocked tried looking for the filter and put back together tried again and the fault is now f11
  • 1 more comment
  • paul squire Jul 19, 2009
    indesit wixe 127 thanks
    hiya thanks for your advice but could you please describe what the filter looks like and where it is located because i have had most of the pipes off and cannot find it
    could you please describe where the filter is and what it looks like because i have had the pipes off and looked about and cannot see anything obvious there is a white plastic tubing between the pipes but is not blocked.
  • 3,230 Answers
Please provide me the make and model number of your Washer so i can help you...
Thanks
Posted on Jul 19, 2009
  • Mukesh Kumar Jul 19, 2009
    F-11 - This is a drainage problem.First thing to check is the filter behind the kick plate at front of machine.Please note that there will be water in the system.
    double check the replaced filter...
Indesit pwe 8148 w with error code FO5 Is the problem usually either a blockage or the pressure switch? I am going to try to fix it myself but how do i get to the pressure switch to see if it is stuck on...
Hi.
F05 means that the pressure switch shows full all the time:
F05 - Pressure switch jammed on full
The fault is usually fixed repairing or replacing the pressure switch. Before replacing the switch check for draining issues that can trigger F05 and clean the hose connected to the PS. The PS is located inside the appliance in the control panel or at the right side of the cabinet. The part is reached removing the screws holding the top and lifting the top. Power must be disconnected before starting.
Here how the switch looks like:
Sep 14, 2011 | Indesit W 123 Front Load Washer
Code F-05 showing on INDESIT WIXE 127 washing machine. Not emptying or spinning.
Hi
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove the large black fastened to bottom of the drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps you.
Jan 03, 2011 | Washing Machines
Model WIXE 127 instruction manual I have lost the one provided with new machine
Go to -
WWW.INDESIT.CO.UK
In the menu on the left, click on--- Indesit user manuals.
Then in the search box, enter your model number, and download the instructions.
Please rate my solution to your query.
Thankyou.
Jan 15, 2010 | Indesit Washing Machines
Fault code F05 on an indesit washing machine WIXE 167.it not emptying the water
Locate and remove large black fastened to bottom of drum.
Hop[e this helps you.
Dec 28, 2009 | Washing Machines
Fabric conditioner not going
Check the solenoid belongs to that tray.It may struck.
Jul 05, 2009 | Indesit WA 125 Front Load Washer
My indesit 1300 stops mid cycle and flashes f-05 help
pump blocked take plastic trim off bottom and unsrew filter is main cause or poss pressure switch jammed on full
Jun 07, 2009 | Indesit W 123 Front Load Washer
Manual for Indesit WIXE 127
CLICK HERE
http://www.miaudioaddiction.com/fixya/manual.pdf
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Apr 07, 2009 | Washing Machines
Indesit W123 5 flashes error!!
The F05 fault means the pump is blocked, check the filter at the front bottom right of the machine behind the plinth and if its connected under a sink check the hose & connection
Nov 03, 2008 | Indesit W 123 Front Load Washer
How to remove filter on Indesit WIXE 127 front loading washing machine
You will find there are something like coins trapped in the filter, stopping it turning, get some pliers & try turning it backwards & forwards to dislodge the blockage. If this doesn't work you may have to force the filter & buy anew one
My indesit wixe 127, wont drain and is stuck on error code f05. what doi do?
i think there is a problem with low water level sensor
My 127 fill up with water and i have f-08 error code which is a high level water sensor faulty
Aug 11, 2008 | Indesit Washing Machines
Washing Machines Logo
159 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
