Question about Epson Stylus CX4800 All-In-One InkJet Printer
Paper won't feed into printer. Always gets jammed
Paper won't feed into printer. Always gets jammed. I seems to only feed on one side.
  • 3 Answers
You must have objects foriegn objects inside your printer. i.e. paper clip or some other object . Get your printer and move it side to side see if you can here anything moving about. once its out then perform alignment of rollers using epson maintenance menu.
Posted on Jul 19, 2009
  • Hasam mahmud Jun 03, 2013
    Hi thx but not work, do you have any other idea that could help me
Had a pen stuck inside mine, same symptoms as yours, couldn't believe it, check it out,thoroughly
Posted on Sep 23, 2012
Jamming
Have you tried cleaning the paper pickup and registration rollers? See page 128 in the HL-2700CN User Guide available from the Brother Solutions Center
Jun 02, 2010 | Brother HL 2700CN Laser Printer
Always Paper Jam in Epson Stylus CX3500
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Nov 26, 2008 | Office Equipment & Supplies
Paper jam
it maybe one of the feed wheels are jammed, if you can get it apart then have a look at the gears and wheels, there maybe something jamming the wheel itself.
Feb 11, 2008 | Canon PIXMA iP1800 Printer
EPSON STYLUS PHOTO RX425, PAPER PROBLEM
disconnect the printer from the computer:
>manually feed paper using the paper feed button.
>observe, if the printer pulls only one side of the paper then it´s a hardware issue
Jan 01, 2008 | Office Equipment & Supplies
Paper will not feed correctly, keeps jamming up.
There IS something stuck in the feed path. If the paper starts to feed and then crinkles on the feed side, there is an object stopping the paper moving forward.
Lay the machine on it's back and take a sheet of very stiff card (A5 size approx) and push it through the paper path in reverse. So start where the paper would normally exit and push the card in. You may need to lift the pinch rollers just behind the print head by hand to aid the card through. Keep the card to the side that would normally crinkle but beware of the paper sensor flag. If you force it you could break it off.
Once you get past the pinch rollers behind the print head, push a little further then start to move the card in and out but along the length of the rollers. You should find that sufficient to push out whatever is in the path and having the machine on it's back will help it fall clear of the feed mechanism.
If it does not fall out using this method you will have to remove the covers and try to remove the ASF to get at the object.
Oct 14, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Paper Jams
Take out the paper tray- and examine- the paper pickup on the jamming side. Do the same internally looking at the paper feed track. If you can get a vacuum nozzle and have a good suck out. It is all most certainly paper debris in the feed . Also take a look at www.fixyourownprinter .com
May 17, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Epson Stylus CX4800 All-In-One InkJet Printer Logo
652 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
