Question about Whirlpool LEN2000PW Dryer
Thermal Fuse My thermal fuse keeps blowing on my dryer. I have cleaned out the lint trap but it still keeps blowing after a few loads?
  • 2 more comments
  • Kswens21 Nov 19, 2007
    Thanks, we tried that too! We blew air threw the vent and made sure it got all the way outside. The vent flex looks good too. Any other ideas?
    The vent goes from the basement to the backyard...roughly 8 feet to the ceiling and then 15 feet to the outside. What can you do to clean that out because we did was the leaf blower?
  • Kswens21 Nov 20, 2007
    Thanks, we will try that and let you know!
  • jmatanane197 Jan 11, 2009
    amana ple8517w2 keeps blowing the thermal fuse. i checked the dryer vent in and outside of dryer. everything clean, but still can't figure out why the fuse keeps blowing out.
  • 447 Answers
First of all stop replacing the fuses and using the dryer it could burn down your house. The problem is the vent is clogged (not necessarily in the dryer) make sure also that the vent flex is not excessively long behind the dryer and is not kinked when the dryer is pushed back.
Posted on Nov 19, 2007
  • joey  shearer
    joey shearer Nov 19, 2007
    Ok trust me here.... Even if you get air to blow out the vent issume with some sort of high pressure leaf blower of shop vac its still too clogged for the dryer to work properly. To be sure air should come out it at about the same force it comes out directly leaving the dryer. Where does your vent go?? Is it more than 25feet??? Each 90degree turn equals 5ft of straight pipe. All domestic dryers are designed for 25ft-30ft max.
  • joey  shearer
    joey shearer Nov 20, 2007
    I hope the vent pipe is also constructed with solid metal pipe and not the flexible slinky stuff. If its rigid pipe the best way to clean it is a tool that they should sell at most appliance parts retailers or maybe even lowes and home depot. It should be a brush with poles that attach. Snake from both ends then use leaf blower to expel lint. Then repeat once.
Maytag Bravos XL Dryer not heating- blowing thermal fuse
The thermostat is controlling the temperature, however the Heating Coil may be defective. Check the COIL.
Feb 27, 2014 | Maytag MEDB950YW Electric Dryers
Sears 417.80042990 keeps blowing thermal fuse
Did you clean out the lint filter at the front, heat is the enemy. Clean out all lint from front, if you are handy, get around back and remove all lint and dust by blowing compressed air.
Sep 21, 2012 | Frigidaire FEQ332E Electric Dryer
My dryer keeps blowing the thermal fuse help
Check your lint filter, exhaust duct, and check if duct flapper is opening fully or not. Allow some time between loads and don't stuff too many clothes.
May 12, 2012 | Maytag MDE9700AYW Neptune 174 Electric...
Replaced thermal fuse in kitchenaid keys777 eqo dryer if started working then it has blown another thermal fuse .had a spare fuse .what could cause fuses to fail,thanks
There is a high limit and low limit switch also in the circuit. If either of these fail, it can blow the fuse. Also, if your heating element is shorting to ground, it will blow the thermal fuse. It is standard practice to replace the high and low limit switches with the thermal fuse.
Apr 30, 2012 | Dryers
Thermal fuse blown on kenmore dryer what is the cause
The thermal fuse blows when the vent gets restricted and builds up too much heat. After it gets to a certain point the thermal fuse blows. Clean out the vent, keep the lint trap clean, and hopefully your problems will go away.
Feb 04, 2012 | Dryers
Keeps blowing thermal fuse even after complete cleaning of dryer door and blower and housing. changed vent to bucket and water lint trap. still blew fuse during fourth load.
have you check the fan blades?, is the fan loose at the motor shaft?, check inside the pipe of the blower housing for blockage. did you replace the thermal fuse alone or as a kit?, are ALL the seals in place including the blower seal?. after checking all that try to run dryer without the vent pipe attached and see if it hold.
Feb 12, 2011 | Maytag PYE2300AY Electric Dryer
Dryer will not heat up
A clothes dryer can go for years without any problems. We come to rely on our clothes dryer, and we can even begin to take it for granted. Then one day we attempt to use our clothes dryer and it has no heat to it. Now we have entered the world of clothes dryer repair, and it is a world that can get expensive. Before you call out the repairman, try some troubleshooting tips to see if you can get the heat flowing back to your dryer again.
    Lint One of the easiest fixes for a dryer that will not heat up is cleaning out the lint trap and cleaning out the lint from the dryer exhaust. The lint trap should be cleaned out before each usage. Not only does cleaning the lint trap prevent the possibility of a fire, but a lint trap that is filled beyond capacity will cause the dryer to not heat up. If the lint trap is clean, then inspect the exhaust hose and vent next. If the exhaust hose and vent are cluttered up with lint, then the dryer will not generate heat. You can use your hand to clean out the vent, and broom handle to clean out the vent duct in your house. The flexible hose can be detached and cleaned by hand as well. Thermal Fuse A dryer will run on for a very long time, and when the thermal fuse gives up then there will be no more heat. Finding and replacing the thermal fuse is not difficult, but in order to do it you will need the manual for your dryer. Each dryer model is different as far as how to open up the cabinet, and locate the thermal fuse. You may need to purchase the thermal fuse online from the manufacturer, or you may be able to get a universal fuse that fits your dryer from an appliance repair store. Contact the manufacturer of your dryer to see what kind of thermal fuse they recommend. Thermal fuses cannot be repaired, they must be replaced. In most cases it is easy to tell if your thermal fuse needs replacing as you will see the center of it is burned out. Heating Element Another main culprit to a dryer not heating up is the heating element. According to Repair, the heating element is a coil found in the back of the dryer that the dryer uses to create heat. The only way to tell if a heating element is bad is to check the consistency of the current it generates with an ohm meter. If you are unfamiliar with how to do this, you can either replace the heating element and assume it is faulty, or you can have a repair professional test your heating element for you.please comment on these solution by say how rate or vote
Jan 10, 2011 | Dryers
Roper electric dryer keeps blowing thermal fuse. motor will not run when this is bypassed for the time being,but want it fixed immediately. Did clean completely dryer lint trap and air duct to...
Remove the lint chute and give that a good cleaning wash it and the filter out1f161fc.jpgCheck and see if the element is shorted to the frame. That will blow the fuse too.
Sep 03, 2010 | Roper Dryers
Maytag performa elecric dryer blows thermal fuse after 20 loads
you need to clean out the dryer and the vent line,the air isn't moving like it should,there is a block some where and when it heats up hotter than it should it pops the thermal fuse,if you have a long run on the vent line blow it out with a leaf blower,go outside and make sure nothing is blocking the air flow,some outside vents have cages on them so animals can't climb into the vent line,good idea but now it's a lint catch,the air can't blow out and the thermal fuse pops or the dryer takes forever to dry clothes,then clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is,you shouldn't have any problems after that,clean it out at least once a year so this doesn't happen again and you won't have any dryer fires,hope this helps,good luck
Jan 20, 2010 | Maytag Dryers
Keeps blowing thermal cutt-off fuse
You need to remove the front dryer panel clean dryer completely of lint . Even where the lint filter is . Also make sure the vent hose is not kinked or filled with water and lint . I changed a thermal cutt-off 3 times in a dryer within about 2 weeks time . On the last time , removed the front panel and filter housing , and a big ball of lint fell out . Cleaned vent housing and inside of dryer and no more problems since .
Sep 05, 2009 | Whirlpool Dryers
Whirlpool LEN2000PW Dryer Logo
1,523 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
