Question about Fedders Heating & Cooling
My split type aircon wont work properly, water keep dripping
  • 3,600 Answers
Try cleaning the port for the drain plug, when the air is damp outside it will condence a large amount of water. Aslo make sure unit is level so it will drain properly.
Posted on Jul 19, 2009
How to charge a refrigerant of split type aircon.
Assuming you have the proper equipment to service the unit the best option is to weigh in the charge- superheat/subcooling calculations fly out of the window on mini-splits and the frustration and time spent trying to achieve proper refrigerant balance is more pricy than recovering the charge and reweighing it into the system. If you are not experienced in this field attempting to do so can cause major damage to very expensive equipment.
Sep 22, 2011 | LG LS-L1210CL Mini Split Air Conditioner
Carrier split unit aircon mdl 42P100c has water dripping from the unit mounted internally onto floor.
Due to non maintenance of a/c. Col and air filter dust blocked. Due to this, some time ice formation over the coil will be there. Clean air filter, coil and blower wheel. And also drain pan.
If you see any ice formation over the coil after service, it's meant for short of gas. Thanks.
Jan 11, 2011 | Heating & Cooling
HI my samsung split sytem aircon is dripping water on to my carpet? only just started today. Richard
Check outside for the drain hose and make sure water is draining.If not, disconnect hose at evaporator ,and blow it out. Do not **** it from the open end: it does not taste good.
Feb 23, 2010 | Dehumidifiers
Kelvinator aircon is dripping water from air vent in house
Sounds as if unit is freezing over----typically a response to lack of proper ventilation-----check all filters and access panels to unit and clear or clean as needed-----if unit has a drip pan make sure unit has been positioned properly so as to catch excess......properly ventilating unit should resolve issue though
Jan 15, 2010 | Heating & Cooling
I have split system aircon model no ese21hra wont
You should change the remote sensor receiver unit on the unit.
Nov 14, 2009 | Heating & Cooling
What are the instructions re water drainage, I cannot find the manual
Basically the drain pan should tilt towards the drain itself. This so that water would not leak inside. It goes for split type and window type aircon.
I hope this helps
Jul 02, 2009 | Heating & Cooling
Air conditioner dripping water
Try pouring some bleach in drain.
Jun 28, 2009 | Fujitsu 12C1 Air Conditioner
WATER LEAKING FROM MY SPLIT TYPE LG AIRCON
1. Do not set the aircon too low temperature in overcast weather, this will cause ice ups and water dripping. Optimal comfort zone temperature is 24c.
2. You need to open the grill cover on the front of the aircon which unclips either end left and right with a finger pressure. You will find two filters which can slide out and should be cleaned. First tap them together to remove dust, then you can wash them with mild soap and cold water.
3. There is the third possibility that an insect has made a nest in the drainpipe. You should look on the outside of the building and locate a plastic drainpipe. You can either blow into this pipe with your mouth or get a blower. This will unblock any restriction in the drainpipe.
Goodluck and ratemeplease.
Mar 19, 2009 | LG LSC121PMA Split System Air Conditioner
Water dripping from split level aircon on to floor
this time of year it's either from your humidifier or if you have a high effeciency furnace it's because the water isn't draining where it's supposed to.  you need to get to the furance or air handler and make sure the drain line is where its supposed to be.
Nov 29, 2008 | Heating & Cooling
Heating & Cooling Logo
315 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
