Freezers Logo
c
cyril pillay Posted on Oct 21, 2016
I have a aeg full ss upright freezer witch over freezers with ice on top
5 Related Answers
Anonymous
  • 237 Answers
  • Posted on Nov 13, 2006
SOURCE: Whirlpool Freezer Model #EV150NXENOO
This one sounds like the defrost timer is not working and you are not getting a defrost cycle every 6-8 hours (or when needed). Another issue could be that air (moisture) is getting in from a leaky door seal, etc. and causing the freeze up. If you have a sealed system problem where the cooling coils are not uniformly frosted up then the defrost thermostat will not "know" there is an ice condition and therefore not go into defrost mode (same issue if the defrost t-stat is bad). After you have ALL the ice out of the unit it would be a good idea to take the interior rear cover off so you can view the coils. Start the freezer back up and watch over the next 1/2 hour or so to see that the entire coil is frosting up uniformly. If it isn't you may have a plugged system, a leak causing low refrigerant, etc. If over time the coils look uniformly frosted up you may have a defective defrost heating element itself (no heat, no defrost sort of thing). The defrost elements can be checked with a multimeter for continuity if you know how to do that sort of thing. It's hard to know a person's ability by these forums or if they can tackle certain test procedures.
Anonymous
  • 770 Answers
  • Posted on Jul 21, 2008
SOURCE: Kenmore upright freezer
Where do you see the water coming from ?
Anonymous
  • 3361 Answers
  • Posted on Mar 27, 2009
SOURCE: Upright freezer door inside developing ice
The door seal is at fault. Regardless of the small tear it is not sealing well.
Take a dollar bill and close it in the door. Then pull on the bill to feel resistance.
You will find it pulls easily in some place. That is where your air leak is that is causing the condensation.
Do this about every 6 inches all the way around the seal.
buddymcl777
Bruce McLeod
  • 67 Answers
  • Posted on May 04, 2009
SOURCE: Upright freezer not cooling adequately
Go to there website and see if you can find your model. You can also contact them from there.
http://www.aeg-electrolux.co.uk/node145.asp?CategoryID=2595
Also get yourself a stand alone fridge and freezer thermometer - leave it in for an hour -that will establish what the temperature really is which will help in diagnosing the cause.
Also trying unplugging it for 15 minutes so the display board loses power - then plug it back in - sometimes that will reset it.
woodchuck789
Charles T Nevin
  • 4070 Answers
  • Posted on Sep 02, 2009
SOURCE: The top shelf in my upright freezer ices up badly;
If this is the type of freezer where the shelves are the evaporator coils, the coolant goes through the shelves(tubing) and the formation of frost is normal and has to be manually defrosted.All the shelves should be as cold asd the top one. The fact that just one has any frost may indicate that it is low on freon. If this is the case you should notice that the freezer doesn't get cold enought.
Upright freezer not freezing food and ice forming on back wall
is the top of the freezer full where it can breathe remove something to help it breathe
1helpful
Left my upright freezer open a crack and now the
With the door left open moisture would get into the unit behind the walls and into the duct work. The only way to fix this right is to unload it and let it unthaw for a day or so open. Once it is all defrosted and restarted it should be fine again.
Kenmore upright freezer, about 16 cu ft. Buildup
symptoms you are describing are faulty door seals, try putting a thin piece of paper between door and frame to make sure doors are sealing,also when did you do a full manual defrost??(once a year even with auto defrost)
1helpful
Upright freezer-only top shelf gets frost
it may be that the door is open a lot witch lets in warm air that go's to the top of your freezer and turns into ice so there maybe nothing wrong with your freezer, in winter we heat the house up and close all the windows this holds in the damp air,, in the summer it should be ok, but to test it place a thermometer in the freezer is should be about -21*f or there abouts for a 4 star freezer
Dec 29, 2009 • Freezers
8helpful
2answers
My AEG Arctis freezer is not freezing at the correct temperature and seems to stick on -11 even if I put the fast freeze on.I have turned it off for 24 hours and on again but it still does not hold the...
The freezer is probably in need of defrosting. This usually occurs when the freezer has been over packed. It needs to be able to ahve air flow through it, there are holes in the back of the freezer and a defrosting element at the top and they need to be clear in order to keep it frost free. It happend to me and we called an engineer out. solved it by using hair dryer to defrost it.
5helpful
2answers
Aeg fault codes
aeg santo fridge/ freezer
The fridge part of my appliance is not getting cold please help
Top AEG Freezers Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an AEG Freezer Expert? Answer questions, earn points and help others
