Question about Miele W2203 Front Load Washer
Need to know where to put washing liquid in my Miele G646 SC
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 71 Answers
Hi most washing liquids go direct inside the machine with your washing, if your using liquid there should be a small liquid device with the bottle that you also use to measure the amount of liquid and place direct into the machine drum.
Posted on Jul 19, 2009
What type of detergent is best for Miele washing machine powder or liquid
Cost basis: Powder
Convenience: liquid
Residue: Liquid
Cleanliness: Powder
Apr 22, 2016 | Miele Washing Machines
Miele dishwasher G646 SC plus water pump
I would suggest any appliance repair shop or appliance retail store should be able to order one in for you
Sep 06, 2012 | Miele Dishwashers
Miele G646 SC plus I wish to remove the right hand side panel of my dishwasher. I have managed to do this with the exception of the top of this panel. Does the top surface have to be removed to release...
Hi - if i rember correctly on the sides front top panel is a plastic bung, pop this off and you would see the screws inside - oly problem is most of the later Mieles have torqx screws - anyway if you succeed the gently lift front & push backwards - the top will come off.
But the best ways is to empty the washer of water pull it away from the cabinets disconnect everything.
Lie the silly thing on its back on the bottom will be 4 screws normally this will drop the bottom panels & makes it easier for you to work on the machine.
According to the parts manual this would have a waterproof inlet valve system - typical design for Mieles.
JUST BE CAREFUL - Mieles are excellent machines, try not to damage other components - perhaps the leaks is coming from some other - Miele parts are as costly as the purchase prices.
Hope to see how you get on...
Jun 23, 2011 | Miele 24 in. G646SC Plus Free-Standing...
Miele G 880 SC -- dishes not drying
Make sure you are using rinse aid. even if you are using tablets which has rinse aid built into the tablets Miele still recommend using rinse aid liquid as well.
Make sure you have the rinse aid setting on 3ml
Plastic will not dry as well as plates as it doesn't hold the heat.
You could call out a Miele service tech if it is still under warranty and he would be able to increase the drying time through his computer.
Hope this helps.
Mar 20, 2010 | Miele G880 Dishwasher
Miele G646 dishwasher keeps trying to pump out
Had a similar problem with an 846, but with the inlet outlet lamp flashing. the bottom tray had filled with watedr froma dodgy seal. I switched off and disconnected the electricity. Removed the bottom front cover below the door (2 screws behind the pretty kickboard which also had to come off). The bottom of the machien was a big puddle. I dried this out with paper twowel, put the machine back together and it ran fine. I am going to replace the pump seals now as the machine seems otherwise OK.
Good luck with yours. rupertvdpP
May 19, 2009 | Miele 24 in. G646SC Plus Free-Standing...
Miele dishwasher
My O/H found a considerable amount of gunge in the inlet pipe; that seems to have solved it! Thanks for your interest.
Enid
Jul 21, 2008 | Miele 24 in. G646SC Plus Free-Standing...
I HAVE A MIELE G646 SC DISH WASHER AND IT KEEPS LEAKING WATER INTO THE LOWER TRAY AND CUTTING OUT BECAUSE THE FLOOD SYSTEM KICKS IN.I HAVE THE MACHINE IN THE GARAGE WORKING UP ON TWO WORK MATE WITH THE...
have you made sure the water sofener filler neck locknut is tight to the bottom of the dishwasher?
i have had experience with one machine where spilled salt was not rinsed away after the softener was filled and this corroded a very small pin ***** sized hole near the filler neck
Mar 25, 2008 | Miele 24 in. G646SC Plus Free-Standing...
Miele G892 SC dishwasher not heating/cycle won't stop
Miele have cold inlet only. Either element is open circuit, or the relay that switches the element has failed. My money would be on the element first, then the relay. The machine will sit in that mode forever as it is waiting for the temperature of the water to reach a certain temp before telling the electronic unit to move to the next part of the wash. If you need assistance in how to test & how to get to these parts just let me know. But you will need an ohm meter to test the element. Regards
Aug 20, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Miele W1119 not cleaning white clothes properly
liquid detergent is a pain and not as good as powder. liquid detergent often makes machine smell as well i doubt there is a fault with the machine. try putting on a boil wash with no clothes and this will clear out the slime left behind by the liquid detergent. you didn't say what colour the stains are but iy grey or brown it could be from your water supply - a more common problem than you might think. turn off water and remove the supply hose. there should be a gauze filter at one end and make sure not clogged with dirt. also look into the spigot of the vavle and see if any muck there.
May 11, 2007 | Miele Touchtronic W1119 Large Capacity...
Miele W2203 Front Load Washer Logo
299 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
