Question about Panasonic 24V Cordless Sds Rotary Hammer Drill Kit, EY6813NQKW
I have a Panasonic 24V rotary hammer drill (model EY6813). Recently, one of the stock NiMH batteries began sticking in the charger and the drill. Appears as if one of the battery contacts in "welding" itself the the contact on the drill and the charger. There are marks on the one contact that make it appear as if there may be arcing and the plastic around the contact looks melted, but I don't know how that would happen. Its only occurring on the one contact. I sent the batteries away for a rebuild a couple years ago, but the problem just began. I've stopped using this particular battery, but would like to fix the problem, if possible.
    Habit-Forming:
  • 57 Answers
This kind of problem often start in the machines battery contact springs. In the sprigs should be bent or be slack for any reason, poor contact will occur causing heating (as you noticed). This in turn weakens the tension of the spring/contact in the drill itself further. Inspect the contact springs and look for discoloration and moulted plastic around it. You must replace the drills battery contacts to avoid this problem from escalating. The battery may be saved if you gently rub the contact surfaces with an abrasive. Check the charger's contacts although they may not be replaceable so you will have to improvise. Do not use a damaged battery with damaged, misformed, or uneven terminals due to the danger of poor contact and overheating.
Posted on Nov 29, 2010
I have a black and decker rotary hammer drill i can only read 3 numbers of the model it is 045 but its the last three sn number 0481121 under pat 3309541 need parts manuel for
Your one sounds like this one
http://www.ereplacementparts.com/black-and-decker-5045-type-100-rotary-hammer-parts-c-4167_7879_17406.html
However there are three variants on this page.
http://www.ereplacementparts.com/black-and-decker-hammer-drill-parts-c-4167_7879.html
Black and Decker Hammer Drill Parts ' Great Selection ' Great Prices ...
  1. Cached
  2. Similar
Black and Decker 22738 Type 1 1/2-Inch Hammer Drill Parts. 22738 Type 1 Black ... Black and Decker 27106 Type 1 3/4 Rotary Hammer Parts. 27106 Type 1 ...
Black and Decker 5045 Type 100 Rotary Hammer Parts
www.ereplacementparts.com/black-and-decker-5045-type-100-rotary-hammer-parts-...
  1. Cached
  2. Similar
Black and Decker 5045 Type 100 Rotary Hammer Parts .... Drill Parts Hammer Drill Parts Rotary Hammer Parts. Search within model. SEARCH. Discuss ' Repair ...
Black and Decker Hammer Drill Parts & Repair Help ' Fix.com
https://www.fix.com/parts/power-tool/drill/hammer-drill/black-and-decker/
  1. Cached
Shop for Black and Decker Hammer Drill parts today. Find genuine replacement ... (Type 100). Variable Speed Reversible Rotary Hammer · 5014. (Type 100).
Black and Decker Parts - Tool Replacement Parts ' Tool Parts Direct
www.toolpartsdirect.com/brands/blackdecker.html
  1. Cached
  2. Similar
Black and Decker Drill & Driver-Drill Parts · Black and Decker Hammer Drill Parts ... Black and Decker Rotary Hammer Parts Model Schematics and Tool Parts ...
Black and Decker 5043K_TYPE_3 ROTARY HAMMER KIT Parts ' Tool ...
www.toolpartsdirect.com/blackdecker-5043k-type-3-rotary-hammer-kit.html
  1. Cached
Find the Black and Decker blackdecker_5043K_TYPE_3 ROTARY HAMMER KIT parts you need at Tool Parts Direct. Shop thousands of Black and Decker ...
Black and Decker Rotary Hammer Parts ' Tool Parts Direct
www.toolpartsdirect.com/hammer/rotary-hammer/blackdecker.html
  1. Cached
Replacement Black and Decker Rotary Hammer Parts online. Tool Parts Direct has thousands of Rotary Hammer Parts to fix Black and Decker tools. Shop by ...
www.toolpartsdirect.com/hammer/rotary-hammer.html
  1. Cached
  2. Similar
Tool Parts Direct carries the largest inventory of replacement Rotary Hammer Parts for thousands of make and models. Buy Rotary Hammer Parts online for all of ...
Black & Decker Replacement Parts - 1800ToolRepair.com
https://www.1800toolrepair.com/tool-repair-parts/black-decker
  1. Cached
Black & Decker replacement parts for all Black & Decker tools. ... Black & Decker Cordless Circular Saw Parts ... Black & Decker Electric Hammer Drill Parts.
Beyond Parts - Black & Decker ServiceNet
servicenet.blackanddecker.com/Parts/Detail/29096
  1. Cached
  2. Similar
Available, Add Parts to Cart ... Model #, Model Description, Parts Diagram. 5041K Type 1 · MACHO I ROT HAM KIT · 5042-09 Type 1 · HD ROTARY HAMMER.
black and decker rotary hammer drill Google Search
Dec 25, 2016 | Rotary Drills
"pro source" 24v hammer drill specs
I have a pro-source 24v hammer drill same as picture above, with a US charger 120v I need a 240v charger where can I get one in the UK
Sep 20, 2012 | Drills
How can the Panasonic drill Ni-mh battery be rated at 15.6V? It contains 12 cells. Isn't all Ni-mh cells rated at 1.2V? Are there 1.3V cells available? Where can I purchase cells to rebuild my battery?
13*1,2v=15,6 v. There may even be cells located inside the part of the battery pack that is protruding inside the stem of the drill. Could this be the case here? Battery cells can easily be found on Ebay, although good quality cell are quite expensive. You can also try your local hobby/model-plane-car-boat dealer, which usually have a good stock of battery cells. Make sure it is the type with soldering lugs, and that they match you charger. I.e Nicad vs NiMh vs li-ion and so on
May 15, 2010 | Panasonic 15.6v Ni-mh Cordless Drill -...
My hammer drill won't hammer. larger corded model about 6years old. Used heavy about 3x per year.
when was the last time serviced?? If not recently then you would need to replace the o rings and look for other sticking/worn parts. Give me the exact model number and I will try and find you a breakdown and a rebuild kit. They are not that bad if you are handy with tools and take your time. Let me know
Mar 16, 2010 | Bosch 11236VS Rotary Hammer
Hitachi 24v yfa charger green light
hi
it shows you that the battery is charging.
regards savumihai71
Sep 12, 2009 | Hitachi Hxp 18 Volt Li-ion Hammer...
I have a dewalt DW005 24V hammer/plus drill i am having problems charging batteries. the L.E.D lights flashes as though its charging but it has stopped showing continuous light as it should do when fully...
The battery has probably lost it's ability to receive a charge. Is it old? Check the output of charger, should be around 26 volts DC at the output jack.
Jun 25, 2009 | Dewalt DW005K Rotary Hammer
24v dewalt dw005 was using my drill in chisel position for about 25 mins when changed back to rotary hammer it sruggled to get going and was sticking in chisel the lever was fully to rotary.will this...
Hi, You should take it back while the warranty is still fully intact as this is a problem and will not resolve itself.
Good Luck to you, this should Fixya!
Mar 23, 2009 | Dewalt DW005K Rotary Hammer
Battery charger does not work for my bosch hammer drill sds plus .. my dad is an electronics engineer and he requires the circuit diagram to investigate the problem, where can i get one for this model .....
My charger (24 v) died also and repair shop wanted too many $ for repair. I happened on-to a charger for a printer (24v 1 amp) at the thrift store for $3.00 and fashioned a connector for connecting to the battery. It takes about 3 hrs to charge the battery but you must disconnect manually. It has been working for many months. It will do for me untill i find a bargan on ebay. The repair shop said that the part that failed was not a component that can be changed. (Multyfunction chip) Hope this helps for the short term. Enjoy
Dec 14, 2008 | Bosch SDS-plus BULLDOG Xtreme Rotary...
Makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
Feb 06, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Panasonic 24V Cordless Sds Rotary Hammer Drill Kit, EY6813NQKW Logo
559 people viewed this question
Top Panasonic Drills Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Richard Warren
Richard Warren
Are you a Panasonic Drill Expert? Answer questions, earn points and help others
