Problems scanning to PC from DP-180
Can print to DP-180 but not scan from PC or direct at DP-180 to PC. Is there a scanner driver needed to utilise the scanning operation? Dont have a full users manual and the ones on the web dont cover the information needed.
  • 77 Answers
  • scan your computer using norton 360
  • if you dont have upgrade it
  • www.antivirusware.com/norton-360/
Posted on Jul 19, 2009
Scanner problem - Panasonic DP-8020E
try uninstalling printer driver then reinstalling it if this doesn't work then contact adobe support see if they have a patch for this problem
Jul 30, 2010 | Panasonic Office Equipment & Supplies
Hi fixya i have presented this problem a few days
Go to Start\Programs\Panasonic and look for the "Network MFP Utilities"
There is a "Network Scanner Configuration" software that create
s a "Location" for the scanner. The location can well be a network drive or a shared folder on your computer.
Once you create the location, the scanner will pick it up automatically so when you want to scan, you will be able to select the destination (i.e. the location you created)
You can create several locations to be able to save scanned docs in more than one place.
Jun 27, 2010 | Computers & Internet
I dont know how to get it to scan
Do you have the full featured software/driver installed? What OS are you using? Is the computer on and able to see the scanner of the all in one?
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=15403#DownloadDetailAct for the drivers.
Can you start a scan from the computer (MP Navigator or another scanning program (Windows 7 has Fax and Scan for example))?
If the computer doesn't see the scanner, try a new USB cable and plugging the all-in-one to a different USB port on the computer. If you have a print server or USB hub, try a direct connection. Scanners need a bi-directional communication that is very susceptible to signal loss problems that do not affect the printer.
If you did not install the full software before connecting the printer to the computer, you will have installed the OS's built-in basic drivers which does not support all of the buttons on the all-in-one but you should be able to start a scan from the computer.
I hope this helps.
Apr 11, 2010 | Canon PIXMA MP470 All-in-One Printer
Scanner reserved for pc scan
Get the latest driver´s for windows vista or get rid of windows vista it´s not a good OS extremely slow and very messy a lot of problems a resources consumption.
Hope it helps
Jun 25, 2009 | HP LaserJet 3030 All-In-One Printer
I have need the driver of benq scanner 4300
Hi, i lost my original software CD of the benq scan 4300, please help me to download
Jun 16, 2009 | BenQ Scan to Web 4300U Flatbed Scanner
Using D-link dp-300 Printer Canon ImargeClass MF4350d (Multifunction printer) Problem. I can not use scanner fanction. (no problem for printer) Without printer server, I able to use the scanner.
The problem you are having is pretty standard, the IP based printing works for most printers but the scanner require direct(or well faked, direct) connectivity with a USB port which most routers do not provide.
Several companies including Startech and Io Gear make Virtual USB devices which would resolve the issue.
How they work differs as instead of creating an IP printer, the usb device installs on an ip and then a driver you install on your PC(s) connect to the unit over the router and sets up a virtual USB port on your machine so you can re-install the printer as a local printer attached to what it thinks is a local USB port.
Doing this will allow you all functionality the printer offers but will slow down printing and scanning a bit
Hope this Helps,
Chris
Armor-IT
Apr 24, 2009 | D-Link DP 300U (DP-300U) Print Server
Canon mp610 scanning problem
The readme says that some USB hubs have an issue.
I was having problems and was connected via a hub. I removed the hub and connected the printer directly to the back of the PC and voila scanning is all good.
ALex.
Apr 20, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Scanner
This is not a solution just a possible fly in the ointment. I have often found that scanners only work when attached directly to a computer. Scanning over the network is not a solution I have found. You can always share out the printer from the attached pc.
Jan 09, 2008 | D-Link DP 301U (DP-301U) Print Server
Epsom CX7800 Scanner Printer
Windows XP has its own scanning software found within the control panel under scanners and cameras. This appears to provide a more direct method of controlling the scanner because it is part of the OP Sys as opposed to 3rd party scanner software. If the scanner is installed and it appears as an installed option, then try using this approach instead of the actual scanning software.that came with the scanner.
Dec 23, 2007 | Computers & Internet
231 people viewed this question
jasbo
jasbo
