Question about Acer AL1916W 19" LCD Monitor
Input not supported is floating round my monitor screen how do i get rid of it
    Novelist:
  • 159 Answers
You probably need to change the resolution setting in your computer display settings to a setting that is supported by the monitor.
Your resolution setting right now is probably too high to be recognized by the monitor.
1440x900 should be the resolution setting for an AL1916w if your video card will allow that setting
Fran
Posted on Jul 21, 2009
Dell 2407 Can't get rid of "No S-video input signal" message on screen. How do I get rid of this?
Your S-Video connection is referring to a round plug for a TV input signal. Most computers will not have this connection unless you have a TV based video card. If your using a TV 'monitor' as your computer's video device, their will either be a button on the monitor or your remote to allow you to choose the input signal. If you are using a VGA or HDMI or DVI cable as the connector between the two devices, most likely, the light is referring to one of these, as its video source. You will need to match the cable & monitor source detected to get a usable picture output.
Good luck.
Toby.
Sep 28, 2015 | Dell Computers & Internet
When i put pc on this message comes up on screen saying input not supported and it floats round in a little box.
This generally means you have the display resolution set higher then the monitor can support. To fix this press F8 after you turn the computer on. You may have to press it a couple times before the windows loading screen. A black menu will come up. Select safe mode. Your PC will load into safe mode with minimal drivers and settings. Go to the control panel and select display. Change your screen resolution to something lower then the setting is is at right now. If your screen is 19" or smaller try a setting of 1024x768 for starters. If its 20" or higher try 1280x1024 for starters.
Regards, Chris
Jun 30, 2011 | Acer Computers & Internet
MY MONITOR IS SHOWING AN INPUT NOT SUPPORTED FLOATING MESSAGE. I JUST HOOKED IT UP TO AN EMACHINES COMPUTER. WHAT IS THE PROBLEM?
Does the monitor work on another computer? does the computer work with another monitor? I the answer is yes to both then here is the most likely solution
you may have the screen resolution and/or the refresh rate set too high on the emachines computer. For Windows XP: Boot the computer and use F8 to get the Safe Mode boot menu. Choose the first Safe Mode and log in,... if you see windows come up then go to display settings and and change the settings to something low like 800x600 and refresh rate of 60hz. Restart the system and you will the display and can make adjustments from there.
If either the monitor does not work on another computer or the computer does not work with another monitor,.. or if you are not able to see windows from in safe mode,.. you may have a more serious problem with the monitor or vid card.
Feb 08, 2010 | Rosewill 19" 12MS DVI R911E LCD Monitor
Input not supported - floating gray message Win 7
You haven't specified what monitor you use but the gray message is most likely due to your screen not being able to handle the high resolution. Try setting it to a resolution below 1600 x 1200.
Best wishes,
Graemevm
Dec 15, 2009 | ZT Group Cisnet PC Desktop
FLOATING BOX WITH ATTENTION INPUT NOT SUPPORTED
Your monitor has several different video inputs.
Go to the configuration settings on your monitor and select the video input that matches the video cable from your computer.
Nov 12, 2008 | Computers & Internet
FLOATING BLOCK
hi, it means, u need to change the input mode i.e pal/ntsc/vga..etc or whatever options avilable in the LCD menu..let me know
Dec 28, 2007 | Rosewill 19" 12MS DVI R911E LCD Monitor
How do you remove the on screen display?
Sorry, seems like the cctv hardware does not like the type of monitor your using. How you tried a different display and does that correct the problem?
Jun 24, 2007 | X-10 LM929 19IN LCD 12X10-.294MM SPK BLK
Acer AL1916W 19" LCD Monitor Logo
347 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
