Question about Olympus EVOLT E-500 Digital Camera
What size compact flash card can i use in a olympues e500 can i use a 8GB CF card
    Problem Solver:
  • 5 Answers
You should be fine using an 8g card, but do however make sure it is a type I or II and although you asked about compact flash I might add that the XD M type cards are cheap BUT extremely slow so be careful what you go with. Where ever you get the card from check their return policy just in case there is an issue with it. Also might want to enusre your firmware is up to date before you try newer cards.
Posted on Jul 24, 2009
When I insert a Compact Flash card into my TD-20, the green light above the CF slot blinks and the rest of the brain freezes up until I take it out. When I insert the card prior to power-up, I get a blank...
The card MAY be the wrong format for the unit. Also the maximum size for a CF card in this unit is 4Gb. Check that yours is not bigger than that. There has been SOME compatibility problems of flash drives... try a different brand.
Jul 16, 2011 | Roland TDW-20 EXpansion for TD-20 Drum...
THE CAMERA BRINGING A NOTICE ON A SCREEN ERROR CF.WHAT IS POSSIBLE THE PROBLEM.
Digital Camera: How to Fix Compact Flash Memory Cards ErrorIt is not very typical for compact flash memory cards to give you an error. If you do receive an error, it most likely means that a pin within your CF card slot is bent, or your CF card has become corrupted. Unfortunately, if your CF card has become corrupted, you will need to reformat the memory card, which means that you may lose any pictures that were located on the card.
Fixing Your Flash Memory Card
You will want to remove your CF card and the batteries. Take a look inside the CF card slot to see if there is a bent pin. If you find a bent pin, you can correct this problem using a very small and skinny flat screwdriver. Moving very slowly, use the screwdriver to bend the pin back into place. You do not want to use enough force to make the pin back in one shot.
The pin does not have to be perfectly straight, but get it as close to straight as possible. Insert your CF card back into the slow very slowly. You should see the in align itself with the card. You can turn your digital camera on to verify that the compact flash memory card is now working.
Mar 11, 2011 | Cameras
What is the largest size compact flash card can a dc290 use
I am using a 2GB TopRam Compact Flash memory card right now, and I haven't had a problem. With the DC290 in UltraMode, it's estimating that approximately 1900+ photos will fill the card.
Dec 04, 2010 | Kodak DC290 Zoom Digital Camera
Err cf have changed compact flash cards. every
check deep inside the card slot to see if you have any bent pins. They can often be straightened out with a thin screwdriver.
Sep 05, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Minolta Dimage S414 camera doesn't like a new 4GB CF card
Check your manual to see if your camera accepts a card that large.
Aug 30, 2009 | Konica Minolta DiMAGE S414 Digital Camera
What size in inches is a A85 memory card. I put
The A85 uses a Type 1 Compact Flash (CF) card. If you're trying to put an SD card into the slot, it won't work. Using a strong light, check carefully in the card slot that you haven't bent any pins before inserting a CF card.
Aug 26, 2009 | Canon PowerShot A85 Digital Camera
Please Clarify Compact Flash
Not true. I have a 256MB CF card. I'm sure bigger cards will also work.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Can I use 256M in Axim
Not sure about the SD but I don't see why not, as for CF I'm positive it'll support ANY size cf card out there...
Compact Flash card compatiblity
I don’t know why you PDA can not read your card but I found some infrmations about parts which are compatible with e800. As far as I know this types are compatible with e800. Compact Flash Memory Card 1GB (PX1076E-1NME) Compact Flash Memory Card 512MB (PX1075E-1NME)-Type I Compact Flash Memory Card 256MB (PX1074E-1NME)-Type I
Sep 08, 2005 | Toshiba e800 Pocket PC
Olympus EVOLT E-500 Digital Camera Logo
139 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
