Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Shadows the picture and writing have a shadow
  • JVC Master
  • 8,617 Answers
You need to replace the Convergence ICs and feed resistors. You can get the convergence repair kit for your nmodel at the following link which contains the parts and detailed instructions with pictures on CD.
http://www.tvrepairworld.com/
Posted on Jul 19, 2009
Nikon d-90, shadows in pictures
if you're using pop up flash, you'll get more shadows doing a portrait shot than a landscape shot just due to the position of the flash bulb and the angle the shadows are cast.
Jul 06, 2014 | Canon Rebel XT / EOS 350D Digital Camera
I just replaced the color wheel on my samsung hln5065w. Picture is great but there is a shadow on the right side of screen from top to bottom. The shadow on the top of the screen is wider across the screen...
Its a Good Possibilty that its the New Color Wheel causing this,if the colors are not complete on the color wheel then that will be why you are seeing shadow on right hand side of screen.
I know I ordered color wheel for mine and had to send it back,it did the same thing.
I compared it to the old color wheel and the new one did not have Solid colors on it.
Can you see picture behind the shadow? or is it shadow and no picture?
Mar 06, 2011 | Samsung HLN5065W 50" Rear Projection...
Canon 1400 IS: When I take a picture using flash of a close up object, a shadow is cast on the lower right corner of the picture. For pictures that are not taken close up with flash, or taken from further...
It's most likely the shadow of the lens. The flash is above and to the left of the lens, so the shadow of the lens will be to the right and below.
Feb 10, 2011 | Cameras
The picture is clear but every thing has a blue shadow effect and all writing has the shadow about 2" under it.
Hi:
Your problem is the blue convergence IC has failed, there are two convergence IC's in this unit and I recommend you have both replaced because if one has failed the other is not far behind, better to do preventive measures now then later. One IC controls the Blue and the other controls the Red and Green convergence.
Jun 03, 2010 | Mitsubishi VS-45609 TV
Picture has a red shadow. especially
Convergence problem on rear projection CRT TVs.
Apr 19, 2010 | Televison & Video
Shadow on bottom of picture when I use a flash and 12 mm lens
Are you using a lens hood? That could create the shadow.
Nov 11, 2009 | Nikon D70s Digital Camera
Shadows
Sounds like your lense cover is not fully retracting when you turn your camera on, thus when the flash goes off these are creating shadows on your picture.
Nov 23, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
What is the difference between wide and standard on a picture?
You will see more detail in highlights and shadows (i.e. if you are a few stops over exposed, you will still see the details of a white wedding dress. If you are a few stops under, you will see the details of the shadows of large canyons on the beach) using the wide feature. The wide mode is used to obtain a larger dynamic range with the S3. The standard mode uses the same dynamic range as the S2. If you are looking for faster write speeds, you would use the standard mode, as the wide mode takes longer to write information. Standard is also used to obtain a smaller Raw file size. Based on the scene being shot, only a photographer would know if he would need more dynamic range then usual. It depends on the highlights and shadows of the subject or scene.
Aug 29, 2005 | Fuji FinePix S3 Pro Digital Camera
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
103 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
