Question about Hotpoint Washing Machines
Hot water valve not closing
Just fitted a brand new timer kit from hotpoint, changed the hotwater valve, the hot water valve will not close, is there a sensor to control it
  • 221 Answers
There's a water level sensor which sends the electronic signal to the control board to close the valve. There's tiny little pipe going from the top of the drum. at the end of it, the level sensor.
Also make sure you've used Normaly Closed type valve (NC).
None of above? then it's the control board
Posted on Jul 25, 2009
Can i connect hotpolnt aquatic to hot water feed thanks
Yes you could, but the machine is not built for it.
The other problem I see time to time is that the water valve gets stuck due to the heat. Its a cold water valve, not desiged for hot water. (internal gaskets and o-rings dont like heat).
And, your tap hotwater is about 65-80 degrees celsius. Do you want that for all your clothing? I dont think so
May 18, 2014 | Hotpoint Washing Machines
I have a brand new timer 046878578746 strange thins are happening i was doing manual control clear does not stop watering when i open the main ball valve not the two inline valves for the two zones...
make sure the valve is rated for the pressure of your water. I was called out to one that was unable to open or close against the pressure on the water supply. changed it for higher rated valve and it was then ok. look for the bar or psi pressure differential rating.
Oct 21, 2017 | Orbit Hardware & Accessories
Hotpoint HTS18GCNAWW water not shutting off to the icemaker at random
HI .THIS SOUNDS LIKE THE SOLENOID VALVE STICKING.INTERMITENTLY.WATER INTHE PIPE DOESNT NORMALLY FREEZE UP.IF IT DID THEN PROBABLY THE VALVE WAS LEAKING IN VERY SLOWLY THUS FREEZING UP EVENTUALLY.WATER VALVE IS CONNECTED VIA THE TIMER AS IT'S ROTATING.HOPE THIS HELPS ALI
Jul 04, 2012 | Hotpoint Refrigerators
I have an instant hotwater system with the futher most bathroom about 45' away. I am looking at adding a recirculating pump on a timer at the furthermost bathroom to get hotwater quickly in the...
Maybe I am not understanding your problem exactly, but if you have the instant hotwater system installed it should be measuring the temperature of the water in the hot water line and if it drops below the set level it should open the hot water side until the temperature is reached. If it was installed correctly it puts the hot water back into the cold water line so it isn't wasted.
Sep 18, 2011 | Grundfos RCP-96 Recirculation Pump for...
We have a brand new Atwood EHM6 / EHM6-SM Electric Water Heater w/ Heat Exchanger - 6 Gallon - 110v. The water temp is fluctuating. Cold, Hot then back to cold after a minute. It is wired correctly, The...
Be sure cold supply line is going in bottom fitting and hot line attached to top fitting. Any by-pass or vlaves attached to lines in between should be closed. A check valve at top (hot) between tank fitting and hot line is usually recommended as well.
May 15, 2011 | Attwood Atwood Marine Water Heaters...
My front loading washer always fills with water when i am not using it
It sounds like one of the automatic water fill valves in the machine is leaking water when washer is off and the valves are closed. There are two manual water supply valves at the wall behind the washer, one for hot water and one for cold. Close the manual hot water supply valve and allow the washer to sit and see if it fills with water. If it does fill, then the cold water automatic fill valve is leaking. If not, then open the hot water manual supply valve and close the cold water manual supply valve. Allow the washer to sit again and see if it fills. If it does then the hot water automatic fill valve is leaking. Replace the leaking valve in your washer. You can order the new valve online using washer brand and model number on a appliance parts web store, or maybe even find it at a local appliance parts store.
May 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hot water heater is not working correctly on electric
Check that the by-pass valve(s) on or near back of water heater are in the proper position. If your stumped on how they should be for normal operation, remember this. Cold water has to flow into bottom of tank, so that valve needs to be open straight into that fitting. Then the hot comes out the top, so that valve has to be open as well. Any valves in between those lines need to be closed, otherwise it will mix cold and hot . If still not sure, get back to me, with location of any valves there, and I'll guide you through it.
Apr 12, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Only get cold water entering washer ... no warm or hot
1. Close hot water valve behind washer.
2. Remove hot water line from washer side and place it in the drain.
3. Open hot water valve to ensure pressure and hotwater is ok in your drain.
4. If not, problem is home related.
5. If pressure and hotwater are ok, then see if your fill valve filter is clogged where you disconnected the hotwater hose attached to the machine.. Its called a fill valve. Sometimes they get clogged.
6. If the hot water side of fill valve looks ok with no blockage, then you might be looking at a new fill valve.
Feb 11, 2010 | Washing Machines
Hotwater runs continuously
It sounds like a little piece of trash (precipitated solids in the water line) have gotten in the water valve, or, the fill switch has failed.
If you know how to use a voltmeter, then see if there is voltage always applied to the water solenoid. If not, the water solenoid valve is bad. If it does have voltage all the time (when it's not supposed to be filling) then it's the fill switch.
Feb 01, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Changed cold valve
What brand and model do you have, most domestic units have a combination hot/cold valve? You just need a meter too verify the valve is closing, if the valve solenoid is closing you may be having a water pressure issue, too much water pressure can cause leaks.
Jul 29, 2008 | Washing Machines
Washing Machines Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
