Question about Xerox FaxCentre F12 Laser Printer
Restarting all data on printer
Starting fresh, earsing wat was on computer and starting over
  • 208 Answers
Re: restarting all data on printer
Here is how you reste the printer fo default settings.
The Clear System Data Memory option restores all the user-selectable options to the factory defaults.
  1. Press the [Menu / Exit] button on the Control Panel.
  2. Press the [Up] or [Down] arrow button repeatedly to select [Memory Clear].
  3. Press the [Enter] button.
  4. Press the [Left] or [Right] arrow button to select [Machine Setup].
  5. Press the [Enter] button.
  6. Press the [Left] or [Right] arrow button to select the required option: [Yes] or [No].
  7. Press the [Enter] button.
  8. Press the [Menu / Exit] button to return to the previous menu.
  9. Press the [Stop / Clear] button to return to the Standby mode
Posted on Dec 07, 2007
0 characters
3 Points
Printer will print a document but when it reaches halfway it stops printing. Only way to finish printing the document is to restart my pc. Why does this happen? Can this problem be resolved?
When you restart your PC does the printing continue from where it had abruptly stopped printing or does the printer print a fresh copy .
In any case the clean the Print Cartridge Carry Assembly Mount Rod and try freeing up more space on your PC hard Disk for spooling the print data
Jun 28, 2015 | Lexmark X2650 All-In-One InkJet Printer
Pc send print job to printer fine but the printer prints nothing at all
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Dec 08, 2010 | Lexmark Z816 InkJet Printer
Will not work on computer keep telling me to restart my computer
is the computer seeing the printer? data cable secure, has drivers loaded okay,, with pc offplug in data cable,turn on and see if printer has been spotted by pc,,if not ,unplug ,data lead ,run pc for few mins ,turn off ,replace cable ,try again,
Jul 09, 2010 | Lexmark Z645 InkJet Photo Printer
Lexmark x2500 will not feed paper without help
First, you can unplug the printer and replug. You can also restart the printer and computer. If printer is not detected then you should replace the printer cable.
Second, Start > Run > type services.msc > OK
Find printer spooler services > right click stop and then right click start.
Find any lexmark services in the list. If you find any services the Right click and stop and then start in automatic.
Third, Delete all temporary files, and folders.
Fourth, Start > printer > open the printer and delete or cancel all the queue documents.
Fifth, Restart the computer and printer . Now check.
If problem still same then you need to uninstall printer.
You should also delete all entry from registry key.
After uninstall of printer, you can install a fresh installation of printer.
Nov 19, 2009 | Lexmark Z645 InkJet Photo Printer
Lexmark 1300 printer won't work.
Solution#1- If your printer does not show in your hardware list its means that problem belongs to data cable. Kindly check your printer's data cable and plug it properly.
Solution#2- Uninstall printer's software take a reboot and then reinstall its software and then attach your printer or during installation if installation requires.
Good Luck
Sep 03, 2009 | Lexmark C772dn Laser Printer
Have canon mp 620 my computer tells me a document is printing but nothing is printing.While cleaning up my desktop i deleted the solution menu.Help!!!
1. Goto start Remove the data cable from settings printers select your printer open it. If any document pending over there right click and delete it.
2. Remove Remove your data cable from printer power cable from printer and restart your pc.
This will take care of your problem when restarting.
Aug 02, 2009 | Canon PIXMA MP620 All-In-One InkJet...
I have been trying to install a hp photosmart printer onto a acer
Download the drivers from HP website and install teh drivers from website.
Unplug the printer before starting the driver installer software. The setup wizard will tell you when to connect the printer.
Download from : HP Support & Drivers
Mar 27, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Tally 7.2 Data Corrupt
1)Start Tally and at Company Info Screen press Ctrl + Alt + R then select the corrupt company and press enter to start rewrite process.
2)If it does not worked then there is another method for rewrite:-
Click Start > Run > Type ’C:\(Tally 7.2 directory name)\Tally72.EXE C:\(Tally Data path)[space]/
then press enter
for Eg: c:\tally7.2\tally72.exe c:\tally7.2\data /
after pressing enter tally will get open and at company info screen press Ctrl + Alt + R then select the corrupt company.
Nitin Bankar, Pune
Mar 23, 2009 | Tally T2250 Matrix Printer
Driver downloads but printer not showing up at all on the PC
If you do not have a HP Computer then try the following Steps:
Unplug the USB Cable from the computer.
Go to Start> Settings/Control Panel> Add or Remove programs and delete all the programs you see for HP.
If you are not able to deleted them the go to Safe mode and delete them.
To go to safe mode restart the computer and while restarting the PC you should keep on pressing the F8 tab in your Keyboard.
And then go to My Computer>Local Disk:C> Then Program Files> and delete the entry for HP only (Not Hewlette Packard)
Then in Local disk:C go to Windows and open Temp Folder and Empty the temp folder, and in windows folder rename TWAIN_32 as OLDTWAIN_32.
Close all the windows and open recycle bin and empty Recycle Bin.
And then if you have the All-In-One CD the insert the CD and if you get a installation screen EXIT form that.
Go to My Computer and Right click on the CD which should say CDB-AmericasEuro-Express.exe and open the folder which says UTIL> and then you should see a file whic says UNISTALL_L4
Double click on the same and and follow the on screen instruction (There are 4 Unistall Process if it Prompts to restart then try restart later and complete the full uninstall process, if it does not let you to proceed withou restarting then restart and try the same UNISTALL_L4 once again.
And after it restarts reinsert the All-In-One CD and try a fresh new install.
And before trying these steps please go to Start Settings/Control panel>then printers and faxes and delete all the icons for any printers listed there.
Good Luck
Jul 11, 2008 | HP Officejet 5610 All-In-One InkJet...
Xerox FaxCentre F12 Laser Printer Logo
49 people viewed this question
Top Xerox Printers & Copiers Experts
Level 1 Expert
Patrick Carmichael...
Are you a Xerox Printer and Copier Expert? Answer questions, earn points and help others
