Question about Routers
How to connect wireless, wquest dsl with soreson router
Please help me..
I am not able to get it working. I am deaf..
I am using soreson VP for communicating. thanks
  • 556 Answers
Re: how to connect wireless, wquest dsl with soreson...
Can you provide some information so the instructions can be easier
You probably have a modem or router from quest can you provide the manufacturer and model number in a reply? Can you also provide the manufacturer and model number for your wireless router? It is a box that probably has antennas on it. Lastly can you provide the manufacturer and model of any wireless adapters or computers with built in wireless you wish to connect?
You may also wish to consider the following when setting up your wireless router.
for general wireless security see
Posted on Dec 06, 2007
0 characters
3 Points
I just installed dsl and want to use it with my existing router and the router doesnt want to work with the dsl what do i do ???
First, make sure the dsl is working by connecting it to your computer directly.
Next, turn the router off, turn the dsl modem off, connect the dsl modem to the router. Start the dsl modem first, then start the router, then start your computer and try to connect.
Nov 07, 2009 | Linksys Wireless-G WRT54G Router
Vio and d-link wireless router dsl-2640u connection problem
firstly check to see if the wireless is set for wireless access based on MAC address filtering
also check to see if both the laptop and the wifi router are communicating on the same channel
Jun 24, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Connect router to playstation 3
You need to first plug the DSL modem into the router. log on to the router. Configure the router byusing the user name and password as supplied by your dsl provider. once the router connects to your dsl provider, you should be able to connect your playstation to the wireless network.
Jun 02, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can I use my router just as a Wireless router with a DSL .
i doubt it will work. most times the cable companies give you a modem/router all in one box. the problem is there in no inbound connection to recieve an internet signal other than the cable cord connection. with the dsl modem you will need a seperate router. they cost around $40-50 on avg
Feb 05, 2009 | Arris SURFboard SBG900 Wireless Router...
Connecting DSL/Router to DIR-628 internet router.
it is possible but the routers have to be on separate channels
Jan 14, 2009 | 2wire HomePortal® 1800HW Router...
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Sep 06, 2008 | 2wire (1000-400108-001) Router
Siemens speedstream 2624
you have to configer your router are you using dsl or cabel inter net
cabel you dont need to set in log on but dsl you do
secound configer your router wireless i think you are are useing dsl speed stream bell use
Aug 15, 2008 | Siemens SpeedStream 2624 Router...
Wireless router installation
Please see my response to this question. Your university's connection is most probably a LAN connection, so you'd need to follow the instructions as if you had a cable internet connection (unlike DSL, a LAN connection and cable internet connection don't require authentication with the ISP).
Jan 07, 2008 | Linksys Wireless-G Broadband Router
Wireless router
Yes, you can use wireless router with the modem. I guess the actiontech DSl router that you have is also Wireless one. If so, you can use just the DSL router for wireless connection. If you really want to use Dlink router with it, Connect the ( WAN port ) of the Dlink router to the ( LAN Port ) of the Action tech modem [ modem(LAN)-->Dlink(WAN) ]. Once you do this connection, better to do power cycle ( unplug the pwr to the dlink first, then, disconnect the pwr to action tech - wait 1min and plug the pwr to modem, wait for DSL light to be solid , then put the pwr back to dlink ). Make sure DSL light on the modem solid, internet light & WLAN light on the link glowing.
- Make Hardwire connection between the computer to Dlink and check the ip address on the computer whether it acquires the ip address from Dlink and then check the internet connection on the computer, it has to work. if computer not getting ip from dlink, try restarting computer.
- If hardwire connection on the dlink works fine and check the wireless connection.
For wireless configuration or assistance you may check this link:
please feel free to ask, if you have any more assistance.
- Laxman
Nov 22, 2007 | Actiontec (GS204AD9-02) Router...
Routers Logo
98 people viewed this question
Top Routers Experts
 C. Dante
C. Dante
Are you a Router Expert? Answer questions, earn points and help others
