Home | Hard Drives | Vista and USB Wes...
Hard Drives
Problem for Hard Drives
Generic problem for all Hard Drives
Vista and USB Western Digital HD
By Jester R6 on Nov 19, 2007
When i connect the USB hard drive, the computer scans for a driver then displays a message indicating that the USB mass storage device failed.
Do you know any fixes for this
Same Problem
Jan 23, 2009
-   mine is a 750mybook - after installing SP3 for windows XP pro, windows started to report a write failure, system stops for dump, when it returns, the mybook has a new drive number and XP thinks it is an internal device and it wants to format. been thru cables, usb ports (hub and card), forced an install of infcache.1 with functioning usb peripheral: all to no avail.
If I unplug POWER cord, plug it in, plug and pray will see it as mybook and I can copy and paste files from mybook to another drive - for a while. then i get the stall/dump/ and reassignment function. I usually get about 15 minutes to use the mybook.
Device manager, after the dump, sees the usb slot as "unknown device", but when I use "safely remove hardware", it sees the product properly. Other peripherals work: scanner, printer, zip drive, and I plugged a sony dvd duel layer burner into a usb to see if that would work. yup, perfectly fine.
If mybook is the problem, it is a doozy. Any help?
-   beckydotdata
Dec 19, 2008
-   ya... me too fasing the same problem. Vista searching for driver and eventually shows unable to find any driver form the system drive(laptop)-   Guest
Dec 14, 2008
-   No was not helpful -   YN3ELMORE
Oct 07, 2008
-   same thing. my question is under the title of "doesn't want to search for drivers"-   snowmopro88
Sep 10, 2008
-   I have a simpletech 1tb external hard drive and it turns on and lights up and when I plug it in windows tries to install the driver but it fails. It suppose to be plug n' play.-   Dunphy666
Solution #1
posted on Nov 21, 2007
Not Helpful)
diazphi
Rank: Wiz
Rating: 80%, 266 votes
Try to use another USB port might not compatible with greater that 2.0
Was this helpful?
Yes
No
Popular Solutions for Hard Drives
Questions and Unsolved Problems for Hard Drives
Answer
firelite 40 Gb lost the driver where can I get a new one
Answer
I have a 100gb hard drive, I want to change to a 500gb hard drive. What do I do. What are the... (More)
Answer
I have trekstor , I mounted Dvd folder with various VOB & IFO files, And i would like to... (More)
Answer
My 500GB ext. VOX hard drive has been making a screeching sound. It will not start. What can I do,... (More)
Answer
how to put back the seagate system tray? now my seagate freeagent system tray doesn't appear... (More)
6 Other Users Have The Same Problem - Continued
Comment by bill5066, posted on Jun 05, 2008
when i turn on my simple tech simple drive i get a note device not recognized. when i click the note it says no driver installed. the instructions say it is a plug and play but when i click my computer it does not even show any thing plugged in. thanks bill
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hard Drives:
Top Hard Drive Experts
Rank: Guru Guru
Solutions: 14780
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Hard Drive Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
