Question about Exercise & Fitness
Etiger treadmill starts then after 5 secs or so cuts out and E1 error signe appears on console
  • 33 Answers
Your problem is probably that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
Error message E1 has appeared on the console
If you wish to get some details; check the site linked here. Pull up older posts.........
http://electro-medical.blogspot.com/
May 08, 2016 | Exercise & Fitness
E1 error for stamina 320
If you wish to get some details; check the site http://electro-medical.blogspot.com/. Pull up older posts. Surf the site with patience. Check for treadmill article
Feb 14, 2016 | Stamina Products Exercise & Fitness
E1 error after start
this ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display. see the diagram attached.
God bless you
Nov 27, 2013 | Kettler treadmill Pacer
Treadmill E1 Error
Version:1.0 StartHTML:0000000168 EndHTML:0000001348 StartFragment:0000000468 EndFragment:0000001331
clean the speed sensor, test for open or faulty. tight the connector very well. RUN the software calibration for easy troubleshooting and fix it.
see the diagram attached. and follow steps.
God bless you
Version:1.0 StartHTML:0000000168 EndHTML:0000003648 StartFragment:0000000468 EndFragment:0000003631
The Steps for Newer Style Console Calibration
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Mar 29, 2013 | Exercise & Fitness
E1 error code
Lets eliminate the motor first, unplug unit remove motor shroud fin the 2 leads from motor to lower board. Connect a 18v DC battery to the leads this start the motor to move at approx. 1 mph if it does motor is good,if not you may worn motor brushes worst case open connection in the motor.
Now if the motor is good then reconnection the leads and plug in unit the lower board should have some LEDs lit up. Now find the LED that says PWM start unit if that light should start to flicker then the upper board and wire harness are work properly. Turn off the treadmill then turn it on and with a multi meter insert the leads into the connectors that go to the motor, then put the meter on 200v DC then start the treadmill you should get a reading 5 to 10v DC if you get 0v DC then the board will need replacing
Jul 07, 2010 | Cardiozone Supersport Hr Club Commercial...
Treadmill cuts out after 10 seconds and gives an E1 message.
Your problem might be that a magnet has fallen out of place. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jan 23, 2010 | Horizon Exercise & Fitness
Error message E1
hi there we have an E1 error after 7 seconds of operation??
Apr 09, 2009 | Exercise & Fitness
Exercise & Fitness Logo
1,009 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
