Question about MSI P45 Diamond Intel P45 Core 2 Extreme/Core 2 Duo/Core 2 Quad Socket 775 1600 MHz PC3-12800
MSI P45 Diamond motherboard not booting up
I have installed all components correctly and when i switch on my pc, nothing appears on the screen.please help...
  • rusabus May 11, 2010
    What components have you installed? (Specifically, which CPU, video card, RAM, and power supply?) Do you hear any beeps when the computer powers on? If not, is the PC speaker properly connected, or does the motherboard have a built-in speaker? (Note: the PC speaker is not the same thing as the speakers you plug in to hear audio in Windows. It is small and inside the case or part of the motherboard).
    Sergeant:
  • 449 Answers
First check the power suply. If it is ok then check the processor.
Posted on Jul 19, 2009
Is it possible to use intel duel core E5400 processor with MSI B75MA-P45 Motherboard? or any other motherboard support DDR3?
Hello here is the cpu list, for the asus board:
http://www.asus.com/Motherboard/P5QLCM/#support_CPU
Here is the msi site:
http://www.msi.com/product/mb/B75MA-P45.html#/?div=Basic
Your current cpu will not fit on the msi board, because it is a different socket.
The asus board has socket LGA 775, and the msi board has socket 1155.
You have to buy a new cpu for the msi board, to make it work.
Here is the cpu list:
http://www.msi.com/product/mb/B75MA-P45.html#/?div=CPUSupport
If you want to keep the socket 775, you probably have to find a used mainboard, because this socket type is phased out.
Some online stores still have this mainboard type available, but a new mainboard will have the DDR3 ram socket.
Good luck
Feb 13, 2013 | EliteGroup 945GZT-M (V1.0) Motherboard
I have a msi 785gm-p45 motherboard when i boot the computer there is no video on my monitor not even bios shows I'm using the onboard graphics i know it had a graphics card in it before i recieved it...
Hello here is the homepage:
http://www.msi.com/product/mb/785GM-P45.html#/?div=Manual
Try to download the manual.
Adobe reader is needed, to read the content.
Yes, the bios can be reset, by removing the cmos battery, and inset it again.
But i don`t think that`s the problem.
Try to renew the power supply, and check also the ram modules, by removing them and insert, one at the time, and try to boot again.
Any beeb codes ??
Look also at this site:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
Good luck
Jan 21, 2013 | Computers & Internet
Motherboard drivers
Hello
U can find drivers for this MB HERE
Jun 04, 2012 | MSI P45 Diamond Motherboard
How do you get to the boot menu so I can install a new copy if windows on a msi motherboard?
You should be able to just put the Windows disk in CD or DVD drive and boot your PC, Then a boot from CD Screen should appeared. Then just hit "Enter" to start the XP wipe of hard drive and install. OR you can: Push the Delete several times at boot up and this will take you to BIOS. setup screen where you can adjust the settings you want.
May 19, 2010 | MSI 661FM3-V Motherboard
Msi , pc boot , HELLP
Seems like your processor is getting overheated.
Check the heatsink for proper installation, and if possible apply fresh heat release compound.
Also make sure the fan is working and correctly attached.
Please don't forget to rate this answer if it helps.
Jul 23, 2009 | MSI 848P Neo-V (MS-6788-040) Pentium 4...
MSI motherboard
First check thru visual if there are signs of burnt transistors and bulged capacitors. Check for open fuses and resitors, broken lines. And reheat the motherboard if necessary. Hope this gives you hint.
Best regards,
Rosener
Dec 14, 2007 | MSI P45 Diamond Intel P45 Core 2...
MSI P45 Diamond Intel P45 Core 2 Extreme/Core 2 Duo/Core 2 Quad Socket 775 1600 MHz PC3-12800  Logo
327 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
