Question about Mitsubishi VS-60707 60" Rear Projection Television
Tv lost color
Our 42" rear projection Mitsubishi tv worked just fine until suddenly one day last week when we turned it on and we don't get any red, orange, pink, or green colors. Blue and yellow shows up fine but everything else takes a brownish color. What could it be? Our tv is about 4-5 years old. Everything else about the picture looks good.
  • Anonymous Nov 20, 2007
    lost color on t.v. after power outage
    Problem Solver:
  • 18 Answers
Your problem most likely is on the signal board is my guess. If your not a technician it would be in your best interest to have him check L2C60 on the signal board.
Posted on Dec 27, 2007
When I power up the TV, the fan turns on and I get the green blinking timer light as usual. Once the light turns off I manually boot the TV with the bypass switch and hear the second fan start up but the...
I would suggest it is a ballast problem. You can check supply of 5 volts to ballast's small 5 pin connector (trigger voltage) and about 300V-330V to large 2pin connector. If both voltages present at the start and lamp is working with in another TV - it is bad ballast.
Aug 11, 2010 | Mitsubishi WD-62725 62" Rear Projection...
My tv is showing blue when i turn it on i think my blue projector light is out?
i have a mitsubishi vs-60111 when i watch the tv as of last week the color is pale like green color or green,gray color the picture is sharp yet , i took front cover off the lights are still bright red , green and blue what can be the problem / joe
Nov 06, 2009 | Mitsubishi VS-60111 60" Rear Projection...
The colors red, green and blue went out of focus after unplugging my TV. The text on the screen also is curved and out of focus. The TV was working fine before I unplugged it and it set for a couple of...
Please check convergence out chips on D board of TV that seems defective and causing problem.
Let me know exact model number of TV to provide you more info.
Oct 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Mitsubishi VS50605 rear projection TV won't come on
The power supply caps in the light engine power supply were faulty when they were installed. You need to remove the power supply and take it to your local electronics shop where they can remove the (7) faulty 1000uf 16v electrolytic capacitors and insert new ones. If you remove the power supply yourself (takes only a philips screwdriver) and reinstall it yourself, the electronics shop shouldn't charge you for more than an hour worth of time. The caps would be about $10.
Here's a photograph (thanks Don Crawford).
Nov 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Need help repairing Mitsubishi VS 4541 rear projection TV
Visit the site linked here for more details. Repair of many popular brand devices are given.
Mar 23, 2017 | Televison & Video
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi projection TV WS - 55413
any flashing LED's when running service mode or convergence signal?
Apr 27, 2008 | Mitsubishi WS-55513 55" Rear Projection...
No red, orange, pink or green color!
Sounds like your green tube is low or is bad
Mitsubishi > VS XXXX
this model is famous for fluid leaks. each projector True True (``````````` (``````````` 0 95250 95250 clip_image002.png tube has a reservoir on the front of it with a fluid in it. this keeps the face of the tube cool.
this depends on how bad the damage is in the tv. in most cases we can reseal the tube and clean up the fluid 400-600.
Once you
take the tube out you will see where it leaked. The problem is that the
frame on the CRT that the heavy screws with springs are mounted on (that
hold the lens coupled to the CRT) is weak and they can bend. We have seen
several that have leaked after the customer moved the set. You can only
tighten them down so much because the frame bends. It is just stamped metal
and not welded at the corners to support the bend.
We remove the CRT, clean it all up, add a very small amount of RTV sealer to
the gasket, reassemble, let the RTV cure thoroughly and refill with coolant.
The extra sealer should prevent future leaks. Haven't had a recall yet.
Mits says replace the CRT...too costly.
You msut check the yokes carefully as well. If any coolant gets into them
you can end up with shorts there and a mess.
Clean the boards carefully and repair any corrosion damage. The coolant is
ethylene glycol and glycerine which is water soluable.
Nov 19, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi VS-60707 60" Rear Projection Television Logo
188 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
