FixYa.com
Tags:
Epson Stylus CX4800 All-In-One InkJet Printer
Epson CX4800 in scan mode
posted by edjack on Nov 19, 2007
Scanning at resolutions greater than 200 dpi causes an error message that says the computer cannot communicate with the scanner. This happens after some time into the scan. Epson is on USB 2.0.
There are also times, when printing, that the PC gets impatient with the HP laser printer, and messages that the document did not print, but it is still printing. HP is on ECP Centronics port.
I suspect that there is a timeout somewhere, but I don't know what to change. This is a home-built PC: ASUS mobo with AMD 2 GHz Athlon 64 X2, 667 MHz memory, XP Home Edition SP2.
The scan problem is lesser (I can use a higher resolution) when using a slower HP laptop.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Can you Help with these Printers problems?
Epson stylus cx4200 scanner
Every time I want to open it it... Answer This...
won't scan
the error light is on and the... Answer This...
lost manual for cx4800- how do...
How do you clean the heads of a... Answer This...
scanner bar
the scanner image has a grey... Answer This...
Paper tilted, not equal margins...
Hi. This color printer scanner... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
