When i switch the washing machine on it made a strange noise, then said to check water supply, i did so turned it on again & it is saying F1 on the screen now
  • 35 Answers
Check the float sensor of the machine... some washing machines are eqipt with float sensors... the dont work if they sense that there is no water in tyhe tub....
Posted on Jul 19, 2009
  • roderick lu
    roderick lu Jul 19, 2009
    check the float sensor of the machine... some washing machines are eqipt with float sensors... the dont work if they sense that there is no water in tyhe tub....
Washer was working.. electicity whet out... when emergency generator came in.. door lock message.. nothin I do works
Why is the "F dl" light come on - Kenmore Elite HE3 ...
https://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
Troubleshooting - Support - Dexter Laundry
www.dexter.com/support/troubleshooting/
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
Why won't the door open on my Kenmore front-loading ...
Dec 10, 2015 | Washing Machines
Code F1 E3
F1 Water supply/low water fill ·Check water supply to machine
·Replace water inlet valve
May 22, 2015 | Washing Machines
Son put normal dish washing liquid in top draw!
ok, the machine flooded and the water has leaked into the bottom of the machine, 1st turn off the machine at the power point. 2nd- open the top drawer and remove the suds from it. 3rd. open the bottom drawer and look under it to the bottom of the cabinet . that is where the water will be. use a torch if you have to. now you need to dry the water up. you can do this with a hair dryer or a fan heater. the reason the machine is flashing F1 is because the water has triggered the flood switch and you need to dry up that water. please reply 4 more help.once dryed F1 will disappear. please make sure all the suds are removed from the top drawer. good luck
May 14, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
E20 showing on display, machine still got water in
E20 is related to the pump and as you say a strange noise is there I would check the filter for foreign objects.E90 is normally a communication problem between the main programmer and the display module.There may have been a fault in the pump which has caused a fault at the Programmer.That model was first produced in 2002 but it is worth checking pump and filter first.If you find anything in filter then clean it out and give it another go the E90 error may have been a glich.Best of luck.
May 04, 2010 | Zanussi FJD1666W Front Load Washer
Washing Machine 8kg - Westinghouse LT8195A is showing fault code 1f. What is the full description of this code please?
I was unable to figure out any error which says 1F. I suppose you wanted to say F1.
Check the fault code status :
http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-washer.html
F1 means Water supply/low water fill .
Thanks
Mar 02, 2010 | Washing Machines
Broken washing machine
your door gasket is defective causing no water cut off, so tanks full & water overflows drawer. it get very heavy so strange noise.
Nov 02, 2009 | Whirlpool Washing Machines
Have a GE washer model WWSR3090TAWW, S/N DT106239G. The washer overflowed, and repaced the water level switch. It tested okay. Later when a load was done, it did the same thing. I have checked...
Here's the acid test: If the water is overflowing, turn off power (timer off, unplug machine, or switch off breaker) and if water stops flowing, you have a bad water level switch or obstructed water level tube leading to the level switch. If the water continues to flow in when power is off, and the only way to stop it is to shut off the water supply valves, then replace the water inlet valve of the washer, which for your machine is part number WH13X10024 and generally goes for about $50.
Aug 21, 2009 | Washing Machines
Lights on but wont start- can I reset it model GW608 fisher &paykel
  • Hi,
  • try these:
  1. Check that the washer is plugged in securely
  2. Check the circuit breaker or fuse box
  3. Test the outlet for current
  4. Check that the water supply valves are turned on
  5. Inspect the filter screens
  6. Test for overheating
  7. Test the water level switch
  8. Test the timer control
  9. Test the lid switch
  10. Test the water inlet valve
  11. Inspect the water pump
  12. Test the centrifugal switch
  13. Test the motor
please rate my suggestion....
May 22, 2009 | Fisher Washing Machines
Motor makes loud rattling noise during rinse cycle
could be the coupler and the only way to truely check it is to take the pump, then the motor off. But it seems strange to me that you say it works fine. Is it spinning? usually when the coupler breaks it sounds horrible and usually will not spin but it will drain.I would check the coupler again.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Error code 7 - EcoSmart Washer - Fisher and Paykel
Hi there, what is the exact model of you washer?
Mar 22, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
