Question about Troy Bilt 5.5hp Self Propelled Mower
How do you change the pull cord on the mower - Troy Bilt 5.5hp Self Propelled Mower
  • 76 Answers
Hi
follow the instruction in :
http://www.cockeyed.com/lessons/mower/mower01.shtml
hope it helps
good luck
Posted on Jul 19, 2009
How do I fix the pull string on a push mower?
Hi Barbara:
The pull start assembly is usually attached by 3 or 4 bolts.
Start by removing it. Depending on where the pull cord broke, you may be able to use it shortened a bit, but replacement is probably a good idea.
There is a spring inside the thing the cord winds around (spool)that retracts it after you've pulled on it. The tricky part is making sure that the spring is wound up enough after you've installed the replacement cord.
Look at the way the old cord is installed. If you can, grab it with some pointy pliers and pull it all the way out, winding up the spring tension at the same time. There should be a way to hold the spool (look for a hole you can slip the end of a nail into) so you can change the cord. Then Take the nail out and make sure the cord retracts all the way.
Next step is to re-install it on the mower.
Cheerfuls!
Jun 13, 2015 | Garden
How do i replace the pull starter cord in a Briggs and Stratton lawn mower engine?
3-4 wraps around the pulley, and then the length to the handle.... adjust to maintain a slight tension on the cord by knotting the line in the handle. exact length changes from mower to mower.
Sep 20, 2014 | Garden
Pull cord stuck on lawn mower
Pull cord stuck on lawn mower YouTube
https://www.youtube.com/results?search_query=Pull+cord+stuck+on+lawn+mower
Sep 06, 2014 | Toro Garden
How to change the pull reel
Just click on the link below and it will have videos that will show you how to change the pull reel. Good Luck and I hope this helps you out. : > )
How to replace a lawnmower pull cord - YouTube
Jul 24, 2014 | Toro Super Recycler 21" 159cc Personal...
Model #911503 ,serial #000278 The pull
Here a couple of links with instructions on replacing your rope... Text Good Luck
Jul 03, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
I have a Lawn Boy 10685. Changed the blade and went to start the mower and the pull cord will not pull. I tried spinning the blade by hand with no luck. I took the starter apart and it spins fine. I check...
Remove the spark plug and try pulling the starter again. You may have a fuel leakage into the cylinder and it has caused a hydraulic lock. Check/change the needle and seat in the carb as this leaking is the usual cause if this type of problem. Good luck and please rate this solution.
May 22, 2011 | Tecumseh Lawn Boy Push Mowers Insight...
There is no slack in my pull cord so i can't get it started.
Change the pull cord do you really need someone to tell you this!!!! In any case try this website and try using some common sense next time PAL. Go to smalleng.com they have video on how to do what you need. Check it out awesome website! The cord you can buy at any local home center. or repair shop.
Jun 07, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
I changed the blade, and now it won't start!
Did you replace the blade with a heavier blade, or an identical one? If the pull cord won't pull, it's usually either the blade or the blade shaft causing the problem. Try oiling the shaft and making sure nothing is obstructing the blade from turning.
If you have a pair of heavy gloves, try turning the blade by hand and see if it moves. Squirt some oil onto the shaft where it meets the mower and try turning it again.
May 25, 2010 | Craftsman 22 in Precision Cut Lawn Mower...
How to change the pull starter cord.
drill out rivets then re-rivet or use self tapping screws
Oct 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Mar 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
256 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
