Question about LG Washing Machines
Trouble with it spinning - LG Washing Machines
    Sergeant:
  • 175 Answers
Hi..It is probably due to the belt.you may need to replace
it with a new one.
check it out..
thank you..
kindly rate my response..
Posted on Jul 19, 2009
Why does a 2007 dodge caravan transmission stay in first 1st gear after spinning on ice. Once the trouble codes are cleared the transmission works fine ok
the sensors recognise the wheel spin and compensate by shifting into 1st gear which should maximise traction as wheel spinning at a higher speed can cause loss of control
Feb 09, 2017 | Dodge Caravan Cars & Trucks
HOW fix myadmiral washer model AED4475tq0
check the clutch may be slipping and for good measure check the door switch with multi meter for continuity
Jan 14, 2015 | Admiral Washing Machines
My admiral washer model atw4475tq0 is having trouble spinning and i also have a admiral dryer atw4475tq0 that is making a thumping sound
washer: check clutch assembly links with instructions here https://www.youtube.com/watch?v=tVc6SZ2DD4U
dryer: check support weels (2) for a flat spot or if theyre hard to turn
Dec 11, 2014 | Admiral Washing Machines
Why does my washer do every thing but spin dry could a pressure swicth be bad on door?
Good Afternoon Dale,
I see that you are having trouble with your Frigidaire Affinity washer, model# ATF7000ES, not spinning your clothes dry. First, if the drum is not spinning at all, I suggest resetting your appliance by either unplugging it or shutting the power off at your home's circuit breaker for 2-3 minutes. Once power is restored run a spin only cycle. If it starts spinning and the clothes are still coming out damp, try one of the following:
    1)Try changing the spin speed to a higher speed.
    2)Make sure that you have not overloaded your washer.
    3)Make sure that the wash load is not too small. If you are only washing a couple of items, try adding 1 or 2 similar items to balance the load.
    4)Try rearranging the load to allow proper spinning.
    5)Check the drain hose for any kinks. If it is kinked, straighten it.
    If you are still having trouble with your washer spin drying, I suggest contacting your local authorized technician. Hope this helps.
    -Best Regards-
    WP
May 01, 2014 | Frigidaire Affinity ATF7000ES Front Load...
Duty heavy stackable
Hello Tabatha,
I see that you are having trouble with your washer portion agitating and spinning out. I suggest to give your appliance a hard reset. You will do this by either unplugging it switching the circuit breaker it is attached to, off for 3-5 minutes. Once the 3-5 minutes has passed, switch the circuit breaker back on. Turn the washer on. If you are still having trouble with it not agitating or spinning out, I suggest you contact your local authorized technician to come and diagnose the washer, to see why it will not agitate or spin.
-Best Regards-
Jan 24, 2014 | Frigidaire FEX831CS Top Load Stacked...
DOES NOT SPIN FASTER
Hi Gamaliet Figueroa,
Ii understand that you are having trouble with the washer spinning faster. The washer is preset to automatically go into the HIGH SPIN SPEED for most cycles. If you are having issues with clothes coming out damp, double check that the speed setting is on HIGH SPIN. If that is not the case check to make sure that you are not overloading the washer. If you are still having trouble, what i would do is try to speak with the manufacturer and see if they are able to find out what is going on with your washer.
-Best of Luck-
Jan 05, 2014 | Frigidaire GLTF2940ES Front Load Washer
Not spinning on spin cycle
No spin is electrical!
Nov 28, 2012 | Washing Machines
The ps2 has trouble spinning and reading disc.
it means your playnstation lenses have a problem
Jun 15, 2009 | Sony PlayStation 2 Slimline Console
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
