Question about Nokia E51 Cellular Phone
Only white light on
Upon power reset, only white light comes on for about 25 seconds. No display. No sound. No ********.
  • 298 Answers
This is a software/ firmware issue. I suggest you check Nokia's PC software siute to download the software again. Alternatively you can go to an authorised professional service outlet to get the job done.
Posted on Jul 19, 2009
I have a Samsung 46" TV (LCD) which will not display a picture. The white light in the bottom center area lights up and the Red Light in the bottom right hand corner continues to blink. Finally, about...
had a totally knackered Samsung power supply which had to be replaced when I fitted new psu had clicking coming from new psu which turned out to be a faulty relay on the new Samsung p.s.u replacing the relay on the new power supply board got the TV working 100%
Mar 26, 2015 | Samsung Televison & Video
Android tablet fails to boot. "Green Man" screen comes on, start stalls on next screen
you will need to try power +volume +up +down
Or power +home +volume down then
Factory reset
Dec 10, 2013 | Computers & Internet
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
How do i reset the oil light on my 95 fleetwood cad
1993 BROUGHAM & 1993-96 FLEETWOOD
Oil Life Indicator
1. Oil life indicator will display CHANGE OIL when oil change is needed, based upon engine oil temperatures and driving patterns. After changing oil, reset
oil life indicator.
2. To reset, turn ignition switch to ON position. Do not start engine. Fully press and release accelerator pedal 3 times within 5 seconds. If CHANGE OIL light
comes on and stays on for 5 seconds, it did not reset. Reset system again.
Jun 08, 2010 | 1995 Cadillac Fleetwood
F13 flashes on my Frigidaire electric range
F-13
Control's internal memory may have
become corrupted.
1- Press Cancel key.
2- If fault returns disconnect power, wait 30 seconds and
reapply power.
3- If the problem persists upon power-up replace the display
board.
Sep 25, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Orange record light is on, unit will not display blue power light. Unpluging unit and reset does not work. TV shows white noise.
You could try holding the power button for 5 seconds and see if this resets the unit. It sounds like it may have a internal hard drive issue. if it is under warranty they may fix it for you.
Sep 23, 2009 | Televison & Video
Picture breaks up after approx 25 seconds on my LG RZ-42 PX11
Sounds like the digital board or one of the connectors going to the display
Jun 19, 2009 | LG 42PX4DR 42 in. Plasma TV
Press power button green light comes on.But no picture no sound,
I have had my WS-65511 fail like this, first at 4 years, second 2 weeks later, then 3rd time yesterday (4/14/2009). In past, the tech replaced a thermal sensor p/n 299P313010A (but Mitsubishi says that part is not for WS-65511 and that it does not have a thermal sensor - go figure). It is a white rectangle with about 30 pins in 2 rows and is soldered onto a board in the TV. List price is about $25. Might be your problem.
Apr 04, 2009 | Mitsubishi WS-65511 65" Rear Projection...
My phone no longer rings.
I have that problem every couple of months. What I did was unplugged the power from the answering machine for about 25 seconds and plugged it back in and then it was fine.
Feb 23, 2009 | Uniden Cordless Phone
Startup issue
Sounds like a problem in the power supply section that will need component-level electronic troubleshooting. If it's under warranty and less than 30-60 days, I would suggest an exchange. If not, I would call the number in the manual for help.
Jan 01, 2007 | Apple Cinema HD 30" LCD Monitor
Nokia E51 Cellular Phone Logo
176 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
