Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Fan Noise coming from back of freezer compartment on Whirlpool Refrigerator Model # ET1FTEXS000. Sounds like fan hitting a buildup of ice chunks. Doesn't happen all the time.
  • Whirlpool Master
  • 1,606 Answers
Check the door seal to ensure outside air not being pulled in . You could have a defrost problem if frost build up on rear freezer wall .
Posted on Jul 19, 2009
STARTED MAKING NOISE THAT STOPS WHEN I OPEN THE FREEZER DRAWER AND STARTS BACK UP WHEN I CLOSE IT COULD THIS BE ICE BUILD UP? IT SOUNDS MOE LIKE A FAN HITTING D=SOMETHING RATHER THAN THE COMPRESSOR
Yes that's an extreme amount of ice buildup usually caused by an air leak through seals on the door or the door on the ice dispenser is not all the way shut you must repair or the refrigerator's going to be damaged manual defrost by unplugging and heating up the freezer compartment will help but it will not solve the problem of air getting in there and freezing the moisture from outside of the refrigerator please provide a model number
Appliance 911 Sea Breeze
Nov 18, 2015 | Refrigerators
Samsung RF26XAEBP frig a little over 2 years old sounds like fan motor is rubbing behind icemaker area when i open the door it stops close the door it starts again how to resolve?
You need to unplug and then remove the rear panel inside the back of the freezer and look over the fan assemblies to insure they are not hitting accumulated ice. Ice buildup around fans can be caused by leaving refrigerator or freezer door open over extended times or defrost component failure. Either way it's a good idea to have a look at the inside of the evaporator compartment to prevent damage to fan blades and food loss. Click HERE FOR=>> Samsung Refrigerator Model RF26XAEBP Parts I will be here if you have questions, Thanks Sea Breeze
Jul 03, 2012 | Samsung RF26XAEBP
Gsh22kgrecc freezer compartment howls
Check to see if fan is loose also check to see if there is ice buildup inside and blade is hitting it
Jan 24, 2018 | General Electric Refrigerators
Noise sounds like fan hitting something or rattling
Check for Ice buildup if it is the indoor fan...
If it is the bottom fan then the bearings are gone and you will need to replace it...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 13, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice accumilation next to fan in freezer compartment
u have a defrost problem need to replace heater and tstat
Mar 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirpool fridge is warm, freezer is working
Check the back wall of the freezer compartment for ice buildup. Sounds like you have a defrost issue.
Feb 22, 2009 | Whirlpool GB2SHDXP Bottom Freezer...
Fan begins to make noise - then fridge stops.
You have a defrost system failure and needs to be checked.
You can manually defrost for a temp fix. Turn it off, take everything out of the freezer, use a hairdryer to warm the back wall, 20-30 min, put everything back, turn it back on and you should be good for a couple of days.
Dec 17, 2008 | LG (LRBC22522ST) Stainless Steel
I have a Sunsung RS21JLSG, and it's not chilling the food like it should. It's making terrible noise, sounds like a generator. Anyone know the problem?
Fan blade is hitting something probably, could be ice buildup in the freezer compartment. Open the freezer door and see if thats where your noise is coming from. If it is coming from the back of the refrigerator at the bottom could be something was drawn into the fan causing you noise.
May 05, 2008 | Refrigerators
Refrigerator freezes up
PLEASE DISREGUARD GUEST FIXYA SOLUTION,FREEZER PROBLEM PROCEDURE IF NOT DEGITAL,FIRST CHECK IF ICE ON BACK FREEZER WALL. STEPS-FIND DEFROST TIMER,BOTTOM FRONT ,BOTTOM BACK, INSIDE FRIG.ON CONSOLE,LISTEN TO SEE IF FAN IS RUNNING IF SO TURN THE DEFROST TIMER CLOCKWISE TILL YOU HEAR A CLICK SEE IF FAN TURNED OFF IF SO YOUR FREEZER IS IN DEFROST,FREEZER WILL COME OUT OF DEFROST IN 20-30 MINUTES IF IT DOES AND THE FAN COMES ON YOU HAVE ELIMINATED DEFROST TIMER&FAN,NEXT REMOVE BACK PANEL TO FREEZER IF THERE IS ICE FORMING REMOVE BOTH LEADS TO HEAT AND CHECK WITH VOLT METER ON OMES,IF YOU GET ANY READING THE HEATER IS GOOD,IF NO READING REPLACE HEATER AND CLIPON TEMINATOR,IF HEATER IS GOOD DEFROST COILS WITH HAIR DRYER TOP TO BOTTOM AND THIS WILL ALSO CLEAR THE DRAIN,IF EVERYTHING CHECK OUT GOOD DEFROST TIMER ,FAN ,HEATER, DRAIN, YOU NEED ONLY TO REPLACE THE LITTLE ROUND CLIP ON TERMANATOR,LET ME KNOW-MIKE
Oct 13, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
344 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
