Question about ASUS W5F - S Notebook
Microphone is muted , not working . I can't find a problem in anny tools. the problem is that button near displau is not workin...
  • 4 Answers
1.If Win XP=Click my computer--> Properties-->hardware--> device manager-->Sound audio devices--> Remove device and restart computer .
2.If this does nt work , Change the sound card
Posted on Jul 19, 2009
I cannot get my microphone to work
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 19, 2011 | Toshiba (P000257700) Microphone
My microphone does not work, the headphones work though...
Click VOICE
In the Sounds & Audio Devices Properties window locate the SOUND PLAYBACK box and click the VOLUME button. Make sure that there is not a tick (check-mark) in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Also make sure that the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it.
However - if you cannot get enough volume on the microphone you may need to purchase a pre-amplifier to boost the signal strength before input to the computer.
Feb 10, 2011 | Logitech (980240-0403) Microphone
My built in mic is not working properly,when I call somebody hear me but I don't hear him!
If the other person can hear you then YOUR microphone is working fine.
The reason may be that his microphone is faulty (solution below)
Otherwise:
  1. Make sure the volume is turned up on your speakers (and if using external speakers they are plugged in / turned on) . To increase volume go to Control Panel, Sounds & Audio Devices and adjust the slider on "Device Volume" . Also click on "Loudspeaker Volume" and adjust the sliders there as necessary.
  2. Can you hear other sounds (like playing music or videos)? If yes then you need to adjust the audio settings for your calling program (skype or whatever). Launch the appropriate program Click on Tools and ' test audio properties' on the program tool-bar. Follow the instructions on the screen.
  3. Try plugging in headphones and see if you can hear better on them.
Click VOICE
That should be it.
Feb 09, 2011 | Toshiba (P000257700) Microphone
My laptop is compaq presario cq40. my microphone is not working but i can hear the voice of the person on the other side
Firstly please check that you have pugged the microphone into the correct (red) socket.
If that is correct the problem is likely to be in the audio settings. You don't specify which operating system you are using. My answer is for Microsoft Windows XP but Vista and Windows7 will be broadly similar.
  1. Click 'start' or go to 'my computer'
  2. click on 'control panel'
  3. click 'sounds and audio devices'
  4. click 'advanced' button in the 'device volume' box. This should open a long window of audio volume controls.
  5. On the tool bar click 'options'
  6. click 'properties'
  7. There is a drop down menu with the label 'Mixer Device' - click the down arrow at the right hand end of this menu. If there is more than one device listed select 'wave device' from the list.
  8. Further down the properties window there are 2 options 'Playback' and 'Recording'. Click on 'Playback'and then look at the list of devices in the box labeled 'show the following volume controls'
  9. Make sure that there is a tick (check-mark) against microphone.
  10. click ok
  11. Now look at the devices listed in the long window of 'volume controls' make sure that there is NOT a tick (check-mark) in the 'mute' box against microphone and that the volume slider is up at or near the top of the scale.
  12. Make sure that the 'mute all' box (far left) is not checked
  13. click on the 'options' tab on the tool bar once more
  14. Click on 'Recording' and repeat steps 9 to 12
Your microphone should now be working but I assume, from your question. that you are trying to use Voice over Internet Protocol / Skype / Messenger or other chat program. If so you will now need to go into the appropriate program and test the audio properties. Exactly how you do this will vary with each different program but most have a fairly simple test wizard. With Skype the easiest way is to select the test call button.
Jan 28, 2011 | Compaq PC Microphone (Black or Beige)...
Microphone not working
How to get your webcam microphone to work: Click on Control Panel, Hardwre and Sound, Sound, Recording. You should see your microphone icon with a Green check mark on it. If there is no Green check mark, it means it is disabled. If there is No green mark on Microphone it never works. To enable the Microphone Right click on Microphone and click on Enable. If you do not see the Microphone in the list, Right click on the White space and select Show disabled devices. Then you would see the Microphone. However, if you do not see the green check mark on it, Right click on it and click on Enable. And also Select Microphone and click on Set Default (If Set as default button is active).
If you see the Green check mark on Microphone the Microphone definitely works.
Step 3: Increasing Microphone Sensitivity and Un-muting the Microphone.
1. Select Microphone and click on Properties button.
2. Adjust the slider until to 100 % of its range.
3. If Mute is on, click the mute button to un-mute the device.
4. If Microphone Boost is available, boost the volume.
5. Click OK to make the changes.
Now the Microphone should work. To verify you can test it on the free webcam test tool site.
Jul 01, 2010 | Logitech Webcam
Camera works but skype tells me the microphone is muted.
Go to Tools | Options | Audio Settings which is how the audio and microphone settings are adjusted in Skype.
Your microphone might be muted in the Windows multimedia sound control panel - if you double-click on the speaker in the Windows taskbar you will get the mixer control panel - select Recording devices if the Microphone is not shown, make sure the MUTE checkbox is clear.
Dec 26, 2008 | Logitech Quickcam Chat Webcam
Hiiiiiiiiiii
in the windows volume control un mute the microphone and also, you can get a program like ventrilo
www.ventrilo.com
its a voice chat software, use the setup to test your microphone.
Apr 19, 2008 | ASUS M2N-E SLi Motherboard
I am using a head microphone
No, depending on what version of windows you are using the microphone is muted by default in the sound properties dialog box.
Double click or right click your volume icon in the task bar area near the clock and go to sound mixer or properties and UNCHECK the mute microphone button. Then adjust the recording level accordingly using sound recorder or similar program.
Feb 10, 2008 | Computers & Internet
New laptop
I had this problem too. My built in mic wasnt working, but i went to the list of programs (Classic view of the start menu) and under the program folder TOSHIBA > Speech System it'll have a choice "Configure Microphone." After I went through that, it worked fine. Make sure you restart your webcam software though after you've done that if you had it open like me. Hope this works!
Jun 07, 2007 | Toshiba (P000257700) Microphone
ASUS W5F - S Notebook Logo
125 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
