Question about Stoves 600SiDOm Gas Kitchen Range
Spark ignitor on;y works intermittently
Spark ignitor works intermittently
They removing the knobs and pull (using insulated pliers) the metal where the knobs were attached.
Posted on Aug 18, 2009
  • jayduro Aug 18, 2009
    TRY removing the knobs and pull (using insulated pliers) the metal where the knobs were attached.
Dryer wont get warm... intermittently works... sometimes canhear the ignitor spark, sometimes not. Completely cleaned all of the lint in the machine, exhaust line, etc... and got alot of lint. Thought it...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 28, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Gas broiler works, but the regular oven works intermittently, can you explain how this can happen.
The ignitor for the oven could be going bad and causing the oven valve to open intermittently. I see this often. Or the oven valve could be going bad... but the usual suspect is the ignitor.
Tom
Aug 10, 2010 | KitchenAid KGRT607 Gas Kitchen Range
The igniters on my Five Star TPN535-BGSW Dual Fuel Kitchen Range don't stop after the burner has ignited. This is a long time intermittent problem that effects the most used burners but not the least used....
Most likely one of these two causes:
1. Corrosion or build up on one of the metal surfaces that provide a path to chassis ground from the ignitor through the burner and frame back to the chassis ground connection to the spark module.
2. An intermittent spark ignitor wire or corroded connection to the ignitors.
There is a 3rd possibility if the range has been worked on ...
Turn on all the burners, if the sparking stops then the problem is that two or more of the ignitor wires have been swapped between burners.
Jun 27, 2010 | Five Star TPN535-BGSW Dual Fuel (Electric...
Weak spark on my gas fire ignitor (pietzo?)
Piezo igniters wear out, they have to be replaced. A weak or intermittent spark could mean that your's is going out. The conditon of the electrode, wire and sometimes the collection box can also cause a weak or intermittent spark.
Jan 25, 2010 | Grilling
Ignitors Do Not Spark
If one of your burner heating elements works only intermittently, it's probably because of worn or bad contacts in the receptacle that the element plugs into. On most electric ranges, you can remove the element by lifting it up several inches and firmly pulling it away from its attachment (receptacle). Read your owner's manual to learn the correct technique for your range.
If, after removing the element, you see that the ends of the element that were plugged in are pitted, corroded, burned, scarred, or rusted, replace both the element and the receptacle.
Aug 02, 2009 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Spark ignitors on gas stovetop wont stop sparking
Make sure yo haven't spilled liquid on the ignitor becuase this will cuase all ignitors to spark constantly. If all is dry, the spark module must be replaced.
Feb 15, 2009 | Cooktops
Gas Range, trouble igniting
It is likely that the ignitor needs to be replaced. If the range does not sense the correct amount of resitance in the ignitor it turns the gas valve off. When the ignitor is starting to fail the problem is intermittent, so the range turns on and off as you have described.
Dec 20, 2008 | KitchenAid KGSA906PSS Gas Kitchen Range
Heater won't ignite when heater is turn on.
See if the spark will arc across the area where the pilot flame is. It should cross the flame. Adjust the spark if possible.
Nov 11, 2008 | Dayton Heating & Cooling
Stoves 600SiDOm Gas Kitchen Range Logo
235 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
