Question about Toshiba Portege 3440CT Notebook
Bios is damaged
When i turn on my laptop , it appears on the screen
Bios is damaged (call ur serviceman)
serviceman! place maintenance disk in drive and press any key when ready.
where do i get maintenance disk?????????
How do i remove a forgeting bios password
Posted on Jun 29, 2014
  • 41 Answers
You will need to go to the website download the bios and the setup utility , place them on a floppy or CD , possibly a USB drive. Re boot to re flash your Bios
don001996
Posted on Jul 19, 2009
Online pc scan
You could run the chkdsk disk utility
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive.
or an easier way to run the chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Optimizers and Diagnostics.
http://download.cnet.com/360Amigo-System-Speedup-Pro/3000-18512_4-75332741.html 5E3422139C19CBED35C14826A44D4605
Improve your PC performance and fix errors.
if the problem is still persisting
Your computer's BIOS screen can be incredibly useful when you need to make certain hardware or system configurations.
How to access the BIOS on your laptop varies from manufacturer to manufacturer and model to model.
Even though Acer laptops are created by the same manufacturer, not all models access BIOS in the same manner.
While accessing the BIOS setup screen in and of itself is not difficult all you need to do is press a key the difficulty is in figuring out which key to hit.
Restart or power on the laptop.
Hit the "Pause/Break" key the moment the Acer boot screen (not the OS start-up screen) appears.
If the OS start-up screen appears before you can hit Pause/Break, you will need to restart the laptop.
Press "F2" or "Del" to access the BIOS set-up screen.
Depending on the age of your Acer laptop, you may need to instead press "Ctrl," "Alt" and "Esc" simultaneously to access BIOS.
Using the arrow keys navigate failsafe or optimized defaults press F10 to safe to cmos and exit to restart.
Jul 15, 2013 | Acer Aspire Computers & Internet
Bios(block 3) is damaged
https://bugs.launchpad.net/ubuntu/+bug/507723
..error message:
Bios (Block 3) damaged. Contact serviceman.
Happens on Toshiba laptops trying to install Ubuntu.
Not fixed after creating floppy disk with v1.30 of BIOS flash rom.
No known solutions yet.
Nov 05, 2011 | Toshiba Portege 4005 (PP400U-002G2JB_1) PC...
I have problem with my laptop hp 530.He do not see hard disc ! The hard disc was cheked separately and it is not ok.I had put an another hard disc (new)in laptop and also he do not see hard disc. I need...
dude did u check ur bios settings. in ur bios setiings u will b having boot options set harddisk in it.
take a camera and click potos of wat error msg it shows and then mail me on
mr.hardhik@gmail.com
if ur able to get into bios then change it.
orelse have an lapi of ur frnd on his webcam place near ur system and come online on a decide time and i will try n help u out
Mar 04, 2011 | HP Computers & Internet
Ok,was starting and then shuting itself off,now it starts, all of the lights are on,but no boot and black screen. for a HP DV6000
most commonly this is called a bios loop, this is due to the fact of a currupted bios command or a damaged cpu. to eliminate bios you must disconnect battery and cmos battery usually located where memory is, cmos battery is a small cable attached to a metal disk. unattach hard drive and restart computer. after restart shut down computer and reattach battery. again start computer without hard drive. if bios screen does not appear and same sceneario occurs then your CPU is fried. If bios screen does appear and you reinstall hard drive and get same boot error then your boot sector of hard drive is gone.
Due to black screen at boot and boot loop I would say ypur cpu is gone.
Sep 27, 2009 | HP Computers & Internet
Bios damaged
You are fortunate that your BIOS has a built-in recovery procedure. However, you will need a working floppy drive to recover the damaged BIOS.
Do you know what BIOS microcode you're using? Specifically, do you have an Award, AMI, or Phoenix BIOS? (Or some other one?)
Award, AMI, and Phoenix all have different procedures for recovering the BIOS. Once you know which one you have, search Google for "XXXX BIOS recovery" (Where XXXX is Award, AMI, or Phoenix).
Typically, the procedure includes placing a BIOS file onto a floppy, renaming it to a specific name (like AMIBOOT.ROM) and inserting that floppy into the drive.
Jul 19, 2009 | Computers & Internet
This message is seen on the laptop screen BIOS Damaged! Serviceman: Place maintenance disk in drive and press any key when ready.
The maintenance disk was simply a floppy with rewritten code on the first few sectors that bypassed any kind of checksum or self-diagnostic. Useful if you lost or forgot your BIOS password. Also let the tech into the bios to look at settings before replacing the chip. Back then it was cost effective. Nowadays they just replace the whole dang shebang.
Here are your main options, in order of attempt:
1. Hold down esc key when booting, see if you can get into bios. If not...
2. Remove battery and disconnect ac adapter
3. Gently disassemble case until you find a round coin-like battery
4. Go out, buy replacement battery, replace battery, then reverse step 3 and 2
If these steps fail, you've a bad BIOS chip, you could try to ...
5. ebay it.
Hope this helps!
Jun 04, 2009 | Toshiba Portege 3490CT Notebook
Acer Travel/Mate C100 will not boot up.
ur hard drive may be damaged or windows corrupted. reinstall window this may solve
Mar 13, 2009 | Acer TravelMate C100 Notebook
Damaged Bios
Please mention the model number
Nov 25, 2008 | Toshiba Portege 3480CT Notebook
Maintenance Disk for toshiba.
Hello tom
The disc should have come with the laptop, I beleave you can order a new one from toshiba.
If this solution was any help at all please rate it as helpfull or fixya.
And if you need anything else let me know, you can ask me 24/7 by clicking
on the ask me button, I will ansver in most cases within 24hours.
Thanks and good luck!
May 05, 2008 | Computers & Internet
Toshiba Portege 3440CT Notebook Logo
296 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
