Question about HP LaserJet 3050 All-In-One Printer
How to receive fax on my home phone
How do I receive a fax on my hp laserjet 3050? Is there a particular button to push when my home phone rings?
  • 1 more comment
  • Anonymous Nov 30, 2007
    cannot recieve faxed
  • lindali Mar 11, 2008
    my hp3050 all-in-one printer can't receive fax. when i tried to fax to my home with hp3050, it always ring and when said busy even nobody picked the phone line.
  • DJO1 Mar 12, 2008
    The instructions state, that if you are using a shared line (fax machine/telephone/voice mail) to set the rings-to-answer to 2 more than the voice mail. My fax is not picking up when the voice mail kicks in. I can receive a fax if I answer the phone and hit the send fax button ...but that's the equivalent of the manual setting which severs no purpose if I'm not at home. If I set the fax to answer before the voice mail, I get my faxes every time BUT the FAX is answering the regular calls as well....therefore all of my callers get the screeching fax noise. Any clues?
  • 4,402 Answers
Changing these settings:
ECM-error correction 'off'
V.34 'off'
Silence Detection 'on'
Posted on Jan 10, 2008
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
Change amount of times fax rings before receiving fax hp laserjet 3050 Page 123
To set the number of rings-to-answer To set or change the number of rings-to-answer, use the following steps: 1. On the all-in-one control panel, press Menu. 2. Use the < or the > button to select Fax setup, and then press . 3. Use the < or the > button to select Fax Recv. setup, and then press . 4. Use the < or the > button to select Rings to answer, and then press . 5. Use the alphanumeric buttons to enter the number of rings-to-answer, and then press .
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 25, 2010 | HP LaserJet 3050 All-In-One Printer
Unable to send and receive fax from hp 3050 series
check the phone line is properly connected and you are getting dial tone and dialing facility from the phone line which is connectd to fax line.go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Jan 29, 2010 | HP Color LaserJet 3500 Printer
HP 3050 Laser Jet: I can receive faxes but can not send fax? Help
Hello !
You need to reset fax settings first, go to the "Service" under the printers Main Menu and click on "Restore Defaults"
And then set the following settings under Fax Setup > Fax Receive Setup :
Answer Mode: Automatic
Rings to Answer: 2
Distictive Ring: All Rings
Now go to "All faxes" and change this settings:
Error correction : OFF
Fax Speed: Medium v.17
If you are using a digital line it would be a good idea installing a filter for the line
Hope this works
You can contact me on :
Jan 08, 2010 | HP LaserJet 3050 All-In-One Printer
Unable to receive fax from HP LaserJet 3050
Please make sure the machine is set for auto-receive in machine set up and make sure the phone cord is plugged into the line jack on the machine. If this machine is not on a dedicated phone line the machine (rings) should be set to pick up before the answering machine does.
Aug 28, 2009 | HP LaserJet 3050 All-In-One Printer
Not receiving faxes
You must have an analog phone line to fax successfully.
Jul 09, 2009 | HP LaserJet 3050 Printer
We are installing a HP Laserjet 3050 fax machine on the fly...
  2. Use the < or the > button to select Fax setup , and then press Menu .
  3. Use the < or the > button to select Fax Recv. setup , and then press Menu .
  4. Use the < or the > button to select Rings to Answer, and then press Menu .
  5. Change the number to 1.
Enjoy the solution
Nikhil Gedam.
Dec 08, 2008 | HP LaserJet 3050 All-In-One Printer
Phone Calls going to the fax machine
There is a PDF file on the CD. It may be helpful. When you set up your fax, did you set your ring-to-answer 2 rings more than your message system? If you don't have the CD, I can email you the PDF file. Let me know.
Feb 22, 2008 | HP LaserJet 3050 All-In-One Printer
Fax receiving problem in 3050
changing these settings:
V.34 'off'
Dec 28, 2007 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
163 people viewed this question
Ben Johnson
