Question about LG VX8350 Cellular Phone
Mine broke in half comepletely
My phone had the typical hinge breaking problem and i tried to fix it but it didnt work so i just used it the way it was until today when i dropped it and the wiress and ribbons all boke i can still call people but i cant see any thing and i wanna get my pictures and videos off it can any one help me?
This will help you for now till you get a new one,  put the phone on speaker,  then on the left side of the phone is the volume control , below that is another button, press it, the click on the right button on the front, (the one you normally use for contacts,  then press down till you hear Prompts, the click that,  then it will say mode,  click that, the press down once and then click ok.  Then after that, click end,  then click the button on the left again,  the the right button like last time,  the scroll till you hear call alert. the click that,  then press down once, then click ok.
this way you will hear what you have selected,  and it will tell you the name or number of the person is  calling,  make sure its on speaker for it to work.
To get the pictures and video on it, when you go to the verizon store,  and get a new one, they will transfer your files, contacts, videos, photos.
Posted on Aug 26, 2009
My valve needle broke of while removing the float in the carburetor and now half of it is stuck in there how can i remove it?
Try using a air nozzle. If the needle is stuck up in there then a good blast of air should take care of it.
Jul 06, 2012 | Garden
No sounds . no voice . no noise on numbers. cannot hear people talking. cannot hear voice mail. will ring. cannot answer
take it your phone has been dropped a couple times? lol..
Does the screen work normally? either way if you havent fixed this yet (seeing as this is 23 days old as i post) your going to have to take your phone apart. you can try the easy way and take the bottom half apart but dont try to take the screen off. there is a flimsy ribbon cable that runs from the top corner of the bottom half through the hinge that is easier than heck to break. after you get the bottom half apart try pressing down on the plug of it to see if it is loose then try your phone again.
the reason i asked if the screen is working is because that one cable usually handles everything in the top half and when one thing in an electrical device (expecially a small one that has a bunch of tiny components) doesn't work there can be no telling what else will go with it
Nov 12, 2010 | LG VX8350 Cellular Phone
Broke the hinge on my Samsung Alias 2. Need to repair it - have the parts! I had earlier broken my LCD and took the ****** apart, and put a new LCD in. Works fine, but not all of the original screws and...
The spring goes under the little plate that is held in by two tiny screws. Its visible when the phone is open vertically with the plastic cap removed from the hinge. Hope this helps. I took my hinge apart after I dropped it and the top half came off... now it's just holding by the ribbon so I'm going to order a new hinge. Verizon is completely useless. They don't want to even know about you if you're phone isn't under warranty and I have 11 months till an upgrade...
Jun 29, 2010 | Samsung Alias 2 SCH-U750 Cell Phone
LG VX5300 Flip Phone broke in half.
Your phone can work again, all you need to do is to get the flexi cable and fix it back in place.
It is not expensive.
It is about $15.
To fix this, these are the processes to follow;
  1. Get the appropriate screwdriver,
  2. Turn your phone over so the battery cover is facing you. Remove the battery cover and battery.
  3. Next remove the 2 rubber stoppers and unscrew the aerial.
  4. Remove the 6 screws,
  5. Next remove the 2 rubber stoppers & screws above the main screen,
  6. Prise the back part away from the rest of the phone by running your fingernail between where the two parts meet,
  7. Unclip the ribbon,
  8. After removing the ribbon cable, carefully lift the metal part that is beneath the phone. Another ribbon will be attached which should be carefully removed.
  9. Take the circuit board & keypad out and you'll be left with what's below it.
  10. Next remove the top part of the phone by pushing the housing in whilst pulling the hinge, which the top part is attached via, away from the phone. This is the hardest part and you'll need to bend and manipulate the housing the get the hinge out. Be firm but be careful so you don't snap the housing.
  11. To open the top half of the phone and get to the screen, run your fingernail between where the two parts of the housing meets,
  12. Try to open up the top part by splitting it open with a credit card,
  13. replace the ribbon and,
  14. Reverse the procedure for reassembly and it's finished.
Take care
Jun 21, 2010 | LG VX5300 Cellular Phone
03 chevy silverado oil,gas,temp,and battery gauges don't work
Pretty common problem with these. Here's a guide to learn how to fix GM instrument clusters yourself, I used it to fix mine and it worked great.How to guide for Silverado instrument cluster repair
Sep 04, 2009 | 2003 Chevrolet Silverado 2500HD
My LG 8350 is snapping in half
I don't see a problem statement here that needs a solution by someone else.
Broken hinges on LG VX-8350 are notorious failure mode for this model. You may be able to find and obtain a water-damaged phone for small money and transplant only the keypad shell body (the broken hinge part) to your phone. To separate the keypad and screen shells on the good body unit, look here:
http://www.fixya.com/support/t1525077-repair_broken_hinge_verizon_lg_vx8350
Aug 26, 2009 | LG VX8350 Cellular Phone
The flip on my daughters Sony Ericsson W350 broke and I can't seem to be able to find out how to replace it. Any ideas?
try going to the store. If you pay for insurance, they'll send you it within 2-3 business days (mine broke, too!)
Aug 13, 2009 | Cell Phones
Hinge on the LG Chocolate by Verizon
It can be fixed, however it may be expensive. I would recommend sending it to LG
Jul 07, 2008 | LG CHOCOLATE VX8500 Cellular Phone
LG VX8350 Cellular Phone Logo
253 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
