Remove your motherboard battery for some times and restart your computer. thanks
Hi i m som
when u open ur bios & select first boot for formate so u must set 2 times to floppy for boot
and resart ur pc
and then select manual boot drive to use + mark and then save it
i hope ur problem will be solv
i m just wendor
have a little bit know. of com. so i give u
If your Bios gives you the option, you want to have your boot priority set to the CD drive. This way when you put in your OS cd, it will boot directly from that and give you the options to format.
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults)
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps you
you would either format or delete all of the data from this drive if it has an operating system on it you would format it
you have to format your hard drive using a third party disc to erase everything on your hard drive
Press and hold that key during the boot up process to enter BIOS the scroll to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos restart
note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps you
thanx sir for the help
thanx 4 solution but i m doing he same ,my boot priority is set to cd drive still it is asking for load optimal defaults
