Question about AOpen i865PEa-7IF Motherboard
My i865PEa-7IF Motherboard with 4gb ram kingstone ddr400, but bios reads 3.5gb. Bios is 103. CPU is P4 630.
    Sergeant:
  • 449 Answers
It is possible that your system is using shared RAM i.e. some of the System RAM is allocated for Video Card. (ehteshamhusain@gmail.com)
Posted on Jul 20, 2009
2*2GB (4GB) ddr2 shows up as 2*1GB ddr2 (2GB)
It could be a problem if you are running a 32 bit operating system. I know that there is a limit of around 2gb on any 32bit windows install. this can be fixed by installing a 64bit version, IF your hardware supports it. You would need a 64bit cpu to install 64bit windows. If this is not the reason you are having the problem, the only other reason that would make sense would be that your motherboard doesnt support more than 1gb of ram per DIMM hence it shows that two are insalled but can only use one gb each. This i think is the more logical answer because I think the limit on GB for win 32bit was more like 3gb. good luck
Oct 08, 2012 | Intel DG43NB Motherboard
I have a DFI LANPARTY UT nF4 Ultra-D and have been been unable to use all of the memory slots. I originally bought 4GB but have only been able to use 2. Is there a setting that i need to enable?
Hi, you can use up to 3 gigabytes on windows xp 32 bit with service pack 3.
You need a 64 bit operating system to use 4 gigabytes of ram.
Here is some info:
CPU
AMD Athlon 64 FX / Athlon 64 / Sempron Socket 939
Chipset
NVIDIA nForce4 Ultra
Front Side Bus
2000MT/s
HyperTransport interface
Memory
Four 184-pin
DDR SDRAM DIMM sockets
Supports dual channel (128-bit wide) memory interface
Supports up to 4GB system memory
Supports
DDR266, DDR333 and DDR400 DDR SDRAM DIMM
BIOS
Award BIOS
CMOS Reloaded
CPU/DRAM
overclocking
CPU/DRAM/Chipset overvoltage
4Mbit flash memory
Aug 30, 2011 | DFI LANPARTY UT nF4 Ultra-D Motherboard
Hi! I recently bought a MSI MS-6741 Motherboard and set it up with a AMD Sempron 3100+(754) and 1GB of DDR400 RAM (Kingston KVR ,CAS 3.0) and Installed Vista Ultimate on the 120GB P-ATA IDE drive attached...
The board does support up to 2GB DDR400 RAM (for more info on the board try here).
You might also find MSI's support site helpful (here is link to your specific board that has up to date BIOS and drivers).
As for why your system only sees 512MB of RAM, I am not entirely sure, you could try running 'dxdiag' (just type dxdiag into the 'run' utility), which should give you a more accurate reading of how much RAM you have available. Otherwise, certainly try the BIOS update. If you are still seeing only 512MB afterwards, I would certainly be questioning the reliability the board (if the RAM has tested fine on other systems).
Dec 02, 2009 | Computers & Internet
Need network adapter drivers aopen i865pea-7if
hai you can download the drives from the following link
Aopen i865pea-7IF
Nov 11, 2009 | AOpen i865PEa-7IF Motherboard
Motherboard ESC k8m800-m2 (v1.0A) 2x1Gb RAM
You have to verify the in the motherboard book if the brand name or vendor of your merory stick is compatible with your computer's motherboard, there all written : Kingston, Samsung, micron etc... Check all details if meets your motherboard's model requirements and make the change if necessary.
If all details are correct, check in your motherboard's manual if there is a special configuration to respect (in withc bank you should place your memory stick and witch order etc)
Sep 02, 2009 | Computers & Internet
RAM not found as 2x512MB
Are you finding these number when you go into your bios or from a program such as CPU-Z? If you are using good quality DDR400 memory, it should be posting with the full amount of memory available. You are using the correct slots to get dual channel, but you may want to try slots 1 & 2 or 3 & 4 to see if it will post with the full amount of memory as single channel. You may also want to have a friend try the memory in their computer to see how it posts, you may have some bad memory.
Apr 05, 2009 | Intel D865GBF Motherboard
Try to install 2gb ddr memory on MS-6741 motherboard
pls check you motherboard manual if it accept that kind of memory because some board cannot accept.
Jan 08, 2009 | MSI K8MM-ILSR Motherboard
GA-MA790FX-DQ6 Mobo not POSTing Should i reset the bios??
no beeps, indicates you have faulty CPU or mainboard.
  • remove all components even RAM and CPU.
  • insert only CPU and Speaker (without RAM or any other componet).
  • Boot and try to hear, there must be long beep for missing RAM, if not then try to re-insert the CPU or change the CPU/Mainboard.
Thanks and Good Luck
Iqbal
May 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Motherboard ASUS P5RD1-VM ram problem
More people should complain with Asus support. Checking Asus forums, you'll find there's an obvious problem with a PCI-E video addon + 2 used memory slots. In my case, I had 2Gb (1 + 1), mb with bios version 1104, and it worked fine; when I installed a new PCI-E card, the system was very... very sluggish. Now I have uninstalled 1 memory, I'm using only 1Gb of RAM with the PCI-E card, and it's working well.
Again: checking Asus forum, this is a reported problem, and a bios bug... Asus should release a new bios version, but they seem not to bother, as this is a relatively "old' mb...
Feb 16, 2008 | ASUS P5RD1-VM Motherboard
RAM DIVIDED INTO HALF
It sometimes happen that for some Motherboard or in any computer hardware that has a factory defect. Pheriperals and other clip on hardware much probably does not work, or maybe it works but there's much more possibilty to have / make problem.
Updating the BIOS i think it may not help, try to install the other ram you been using before and if its read the same capacity then its probably your 2KVR has the problem.
Jan 15, 2008 | EliteGroup P4M800PRO-M Motherboard
AOpen i865PEa-7IF Motherboard Logo
66 people viewed this question
Top AOpen Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Gareth Cockram
Gareth Cockram
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
