Question about Microwave Ovens
Microwave not heating food
It has stopped heating using the microwave function. The oven and grill function seem to be working fine and the light is on. It makes the noise as if it is working but the food comes out stone cold.
  • 3 more comments
  • Topi Dec 31, 2007
    DAnby over the oven microwave wont heat..sounds like it's working but it's not. All other functions like the clock, turn table, exhaust venting etc works fine. 2.5 years old. Any ideas on what I should look for? Where is the fuse located?
  • tinknocker61 Jan 04, 2009
    Hello VEKAT,I have the same unit whirlpool GH5176xps-o and it also won't heat.I have check Magnetron terminal to terminal and have my olm set at x10 and get o ohms.Also checked terminal to body casing in x1k and still get o olms this should be infinite.Or should this be Filament to the chassis.Infinite should that be 0 olms to the right of meter or to the left of meter which would be 220 olms and then oo.I have also checked the volts to the 1100m inverter and it comes up120v.So i am having a feeling it is the inverter. do take care, Harold
    To Topi: I don't know if you resolve your problem,but I have the same one.So I took apart my magnetron and had noticed some burn marks on the inside copper coil.I am not sure if I am testing this item right.In my book it says to check in RX1 the filament terminal,does that mean terminal to terminal? and to check in setting RX1k the filament to chassis is that the terminal to the outside frame? Also a note if your magnetron is out it does have a 5 year warrenty.that is in the back of the book.Harold
  • Anonymous Mar 12, 2014
    oven is working but food not heating give me solution
  • Anonymous Mar 30, 2014
    food stays cold
  • 3 Answers
Check the protector connected at the capacitor and at the magnetron coil windings, check using an ohm meter.,meter should read to zero
Posted on Dec 21, 2007
  • 225 Answers
Check magnetron and related circuit, and control unit and highvoltage section..
Posted on Nov 25, 2007
Microwave seems itis working fine but not heating
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Troubleshooting Tips
Nov 26, 2010 | Maytag MMV4205 Microwave Oven
Microwave blows fuse in microwave mode grill function ok
It is most likely the capacitor has shorted or the rectifier has shorted. Check with ohmeter, but make sure it is discharged first by shorting the capacitor with a wire.
May 21, 2010 | GE Advantium 120 Convection/Microwave Oven
My delonghi 800w microwave oven works but does not heat up food
If your handy with getting the cover off and looking inside... check the obvious.
I suspect :
If both microwave and Heating elements dont work, then I will assume the magnetron is ok, ans we are dealing with a high voltage issue... and you will need at best... a volt meter and or neon troublelight...
moust appliances have a simple schematic inside... I would start with the heating element first... trace wiring back to circuit board... usually one side of the heating element is connected to the white wire (neutral) and live (Hot) side is controlled thru the circuit board... so finding the neutral should be easy... then trace with neon light or voltmeter...
I know easy for me to say... but with everything else working... it doesnt seem to be the microprocessor that controlls the unit...
May 06, 2010 | DeLonghi MW 605 Convection/Microwave Oven
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
Oct 17, 2009 | LG Microwave Ovens
Belling BEL-CJ/SS25 microwave
My Belling BEL-CJ/SS25 Microwave / oven / grill has recently developed a problem. Every time I close the door the turntable starts rotating, even when I'm not using it. It doesn't make a noise, and doesn't seem to be going into any cooking setting, and the light doesn't come on, but it turns until I open the door, when the light comes on and the turntable stops turning. This has only recently started happening, and nothing else seems to be wrong with it, Is this safe or should I get rid of it and buy a new one. The guarantee has expired so repair may be cost prohibitive.
Sep 04, 2009 | Microwave Ovens
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
Jul 16, 2009 | Whirlpool GH4155XP Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Combination microwave oven
What is the nature of the failure?
Can you enter cooking the time?
If so, what happens when you press Start?
Does it run (count down, lights on, turntable on ) but not heat?
Brand and model might help, too, but the basics are the same, so we're happy to help you with more information.
Nov 25, 2007 | Microwave Ovens
Microwave Ovens Logo
395 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
