Question about Toshiba Tecra M2 P-M 1.7Ghz, 512MB, 60GB, CD/DVD, 10/100PTM20U-3PU6X7Z PC Notebook
Some keys on my keyboard dont work
I have a toshibe tecra laptop some of the keys dont work please help
  • Dominic
    Dominic May 11, 2010
    Are your letter keys not functioning or are the hot-keys not responding?
  • 28 Answers
The keys may have dirt and debris beneath them or could be damaged.
Go to Start, select Control Panel and then type keyboard in the search box on the upper right side. A new window will open; click on Keyboard and select either option from the menu to verify the functionality of your keyboard...
Posted on Jan 23, 2010
Toshiba Tecra A8-S8414 keyboard
I'm not sure if it is worth ..but you can get a new keyboard and change it ..To change the keyboard you have to remove teh hinges cover ..remove the screws and slide the keyboard one inch toward teh display ..and lift it up ..pay attention cause it has a ribbon attached on the motherboard and it is sensible
http://www.uspcparts.com/toshiba-tecra-a8s8414-keyboard-p-9904.html
Dec 22, 2011 | Toshiba Tecra A8-S8414 Notebook
Is it possible that a cdrw/dvd of Toshiba Tecra M1 be replaced with a dvdrw?
Yes, it is possible to replace CD, DVD with DVD+RW on Tecra M1. Generally, it is possible to upgrade optical drive on almost all the laptops.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 27, 2011 | Toshiba Tecra M1 Notebook
How do i remove the key board
How to replace your Toshiba Tecra A2-S119 laptop keyboard ?
It's easy to break the flimsy keys on laptop. In order to better protect the Toshiba Tecra A2-S119 notebook keyboard, some friends, instead, use USB keyboard. But if you work outdoors, carrying a USB keyboard is not convenient. You still have to use the laptop keyboard. Once a laptop keyboard stops working, there is no option but to replace it. You can use these steps to replace the Toshiba Tecra A2-S119 keyboard.
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.
2. Remove those screws with a T-8 or Phillips screwdriver.
3. Turn the laptop back over and open it up. Check and see if the Toshiba Tecra A2-S119 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
4. Remove the plastic pieces carefully.
5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.
7. Take the new Toshiba Tecra A2-S119 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.
8. Refasten the keyboard in place at the top.
9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
10. Turn the laptop over and replace all of the keyboard screws.
11. Put the laptop battery back in place and switch it on to check Toshiba Tecra A2-S119 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
You have to remember that once you open up the Toshiba Tecra A2-S119 laptop computer for keyboard replacement, the warranty provided by the manufacturer stands void. We personally suggest that you do it on your own only if you are in a really desperate situation and there is no way you can get maintenance from the manufacturer. I hope this assists you. John
Jan 26, 2011 | Toshiba Tecra A2-S119 Notebook
On my Toshiba sattellite ,neither shift key will work
1. Look at ur keyboard settings.
2. Use caps lock
3. Bash your keyboard with a sledge hammer and put on a big smile....like you accomplished something.
Apr 18, 2010 | Toshiba Satellite A135-S4527 Notebook
No sound on my used Toshibe Tecra A4 laptop.
http://cdgenp01.csd.toshiba.com/content/support/downloads/sr10sndx.exe
Nov 07, 2009 | Toshiba TOS TECRA A4 Notebook
Some kes not working. help!!!
If the problem is intermittent then the problem could just be foreign objects like crumbs and hair that's trapped under the keys.
Turn the laptop off and stand it on it's side with the lid open. Get a soft, dry paintbrush and brush the keys, gently tap the keyboard in various places with the back of the paintbrush to help dislodge anything that's trapped.
Once your satisfied all the keys are clear turn the laptop on and see if it has made any difference.
If it has not then you may need to replace the keyboard.
Good luck.
Sep 16, 2009 | Toshiba Tecra M5 Notebook
I have toshiba tecra model, some keys on keypad are not functioning .. pls advise .. By Renuka
if u have fall something like water or juice then u have to dissasseble ur laptop keyboard and clean the carbon points of ur keyboard using Aciton with tishue but if this not work then u have to change ur keyboard
hopw this will fix ur keyboard
Jul 30, 2009 | Toshiba Tecra A9-S9021V Notebook
Beeps, keys not working, touchpad dont work
That is an indication that the "s" key is stuck on your keyboard. (permanently pressed down...or making contact).
Try to manually move it out of its current state, even though it doesn't seem to be stuck.
That will solve your problem.
Please don't forget to rate this answer if it helps.
Jul 22, 2009 | Toshiba Laptop Keyboard for Satellite L10,...
One Key repiting on my lap top
please go on your shop please and than change keyboard thanks my friend
Apr 05, 2009 | Toshiba Tecra A8-S8514 Notebook
Tecra 8000 PCMCIA driver XP
wooe
i have an old Tecra 8000 happily running XP picks up everything IRDA,sound and PCMIA Ethernet card. i used a 3com one
Apr 19, 2008 | Toshiba Tecra 8000 Notebook
Toshiba Tecra M2 P-M 1.7Ghz, 512MB, 60GB, CD/DVD, 10/100PTM20U-3PU6X7Z PC Notebook Logo
350 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
